Domain size icem cfd block mesh
Old   March 29, 2011, 05:18
Default Domain size icem cfd block mesh
erhan
erhan61 is on a distinguished road
ı wanna do block mesh with icem cfd . For example ı did 3-d rectangular volume model. When ı put the fit window command domain size for example min:0,0,0 max:0,20,20 but when ı create block mesh, domain size shows min:0,0,-2.567e-10 max:0,20,20 why? how can ı fix this situation.how can ı do that this value also is zero?
erhan61 is offline   Reply With Quote
Old   March 29, 2011, 10:39
AB
BrolY will become famous soon enough
It's not a problem at all. A value of -2.567e-10 is so small, that it won't change anything. It depends on the tolerance ICEM has.
Also, keep in mind that you are going to mesh your domain, and if your geometry is not perfect, it's not an issue until your smallest mesh elements size is bigger than your biggest "geometric" gap size.
An example: if you can mesure a gap of 0.00001 meter between two surfaces of your geometry, and if your smallest elements size is 0.1 meter, it would not be an issue. The mesh won't "see" the gap because it's so small compared to your smallest elements.
BrolY is offline   Reply With Quote
Import Mesh from ICEM CFD to CFX Andre Almeida CFX 16 April 19, 2016 04:42
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
prob while exporting icem cfd hexa mesh to fluent mani CFX 4 March 7, 2007 04:41
About Mesh size setting in ICEM Eric CFX 2 July 11, 2006 09:16
Mesh from ICEM CFD to CFX ! Error ! Why ? Thanks ! Vu Trinh Tuan CFX 11 March 28, 2005 20:04
