Mesh Concentration Points
Old   March 27, 2011, 23:47
Default Mesh Concentration Points
Ali
Ali_M is on a distinguished road
I have a mesh made in Ansys Mesher (see attached picture) and would like to add some concentration points (red circles) to the mesh. I know that you can use 'sphere of influence' to achieve this, however, I'm using 'Advanced Size Function' and Ansys doesn't allow the use of 'Sphere of Influence' with that function.
Does anyone know of a different way to achieve this?
Thank you all in advance for your help.
- Ali
Ali_M is offline   Reply With Quote
Old   March 28, 2011, 06:22
AB
BrolY will become famous soon enough
Maybe you could add some curves and points in those areas and then specify the number of nodes on those curves ?
BrolY is offline   Reply With Quote
Old   March 29, 2011, 02:40
Ali
I'm very new to Ansys, unfortunately. How would I go about doing that?
Do you mean that I should go in the DesignModeler and add some points and curves or should I do it directly in the mesher?
Thanks for the help!
Old   March 29, 2011, 03:48
Algates
alagesen is on a distinguished road
you cant draw anything with ansys mesher, you should go with Design modeler. create a plane with 'from face' as reference and draw curves with sketching, then generate.
alagesen is offline   Reply With Quote
Old   March 29, 2011, 10:42
AB
You can also do it with ICEM, just play with the geometry options.
You could rescale your geometry with a factor of 2 for example, and set the number of nodes you want on your new curves.
Old   March 29, 2011, 14:38
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
In ANSYS Meshing, you could try adding a body of influence... This is geometry (any shape) created in DM, but ignored for meshing and only used for sizing. You set it up in the same place that you setup the sphere of influence...
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   April 2, 2011, 19:50
Ali
I thought body of influence was only for 3D models?
Also, once I draw my curves in DesignModeler, should I create lines from those sketched curves so that I can specify the nodes in the Mesher? But if I do this, how can I specify that the mesher doesn't treat it as a solid body? Any help is appreciated. Thanks!
- Ali
Old   April 3, 2011, 10:02
PSYMN's Avatar
Simon Pereira
Oh, didn't realize you were doing 2D... I haven't spent as much time with that in ANSYS Meshing.
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 09:07
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[ICEM] Mesh lines and points Anorky ANSYS Meshing & Geometry 3 December 1, 2009 01:35
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
