[ANSYS Meshing] Creating Hex Boundary Layer Mesh and Unstructured everywhere else |
March 14, 2011, 04:32 |
Rep Power: 16 |
Hi all,
I am studying wing tip blowing and I am trying to produce a structured mesh on my wing and on the boundary layer, whilst having an unstructured mesh around the wing. I have tried different methods to obtain this but I am not getting what I want out of Ansys Mesher. I have used a combination of Multizone, Inflation and Face Sizing (on the wing). I also need a fine mesh on the wing tip as this is where my UDF will be hooked onto. If anyone has any suggestions for me, I would very much appreciate it. Problem Info: 8m Wing, (12m Height, 13m Width, 10m Length from TE) Domain, NACA0012 Aerofoil (1m Chord) EDIT: Sorry I forgot to add a screenshot. However, my problem has now changed. I now do not need a boundary layer mesh as I will be modelling with inviscid solver. So by using the inviscid solver, this will remove wave and viscous drag, and leave only the lift-induced drag being calculated. But, I need to create a structured mesh over the geometry and the domain. I also need very fine cell sizes on the wing tip as this is where my UDF will be applied to. Info: I am studying the effects of wing tip blowing as a means to reduce the lift-induced drag on the wing. Thanks Last edited by NLao; March 15, 2011 at 16:01. Reason: Forgot to add screenshots |
March 15, 2011, 07:35 |
Algates
Rep Power: 16 |
if u attach ur model as a screen shot then it will be very clear!!!!!
ansys, mesher, wing, wing tip |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 07:42 |
Boundary Layer Mesh in GAMBIT | Jane Wilkinson | FLUENT | 2 | December 4, 2006 10:36 |
Errors in Gambit for boundary layer mesh | Mike Spears | FLUENT | 0 | June 23, 2005 12:34 |
Boundary layer for unstructured mesh | Hunter Hsu | FLUENT | 0 | September 4, 2002 11:53 |
immersed boundary method with unstructured mesh | x.zhang | Main CFD Forum | 0 | August 25, 2002 22:57 |
