March 9, 2011, 08:57 |
hybrid mesh-huge tets
Rep Power: 15 |
I generated a hybrid mesh including prisms close to the surface and tets in the middle of the geometry with the help of Tgrid. Unfortunately the tets become pretty huge in the middle of the geometry. I tried to fix the problem via setting a smaller "Max Cell Size" value at "Refinement" and I am getting a larger number of elements then, but the tets in the middle of the geometry do not change a lot. Does anybody have an idea what to do? Thanks a million, Lilly |
March 11, 2011, 11:05 |
Sandeep
Rep Power: 17 |
you have to change the "growth rate" in "Refinement" try with smaller value
March 11, 2011, 11:49 |
Rep Power: 15 |
Thank you!
Unfortunately I cannot find this option at "Refinement" (or somewhere else). Maybe it's because I am using an old version (4.0.16). I just can find: Max Cell Size, Max Cell Skew, Max Boundary Cell Skew, Min Boundary Cell Skew, Min Boundary Closeness and Boundary Cell Height at "Tri/Tet-->Refinement". Is there maybe another option or can I change the "growth rate" in a different way? Lilly |
March 14, 2011, 05:33 |
Sandeep
Rep Power: 17 |
May be try with command in the Tgrid console
1. just type inter first then you will see all options boundary/ exit mesh/ display/ file/ report/ 2. and then type mesh (enter) tritet (enter) controls (enter) cell-size-function (enter) geometric (enter) and then you will see the default value in square brackets and then type the value what ever you want and enter. thats it the value is changed and do the tritet mesh as normal this is the method in TGrid 3D 5.0.6 cheers |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 01:27 |
[ICEM] Using a hybrid mesh for a simple pipe | Udio_NT | ANSYS Meshing & Geometry | 17 | October 18, 2012 15:42 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 14:40 |
[ICEM] hybrid mesh | vmlxb6 | ANSYS Meshing & Geometry | 5 | March 9, 2011 14:44 |
[Other] hexa vs hybrid mesh convergence | Viais | OpenFOAM Meshing & Mesh Conversion | 0 | April 23, 2010 11:39 |
