Not able to mesh a helix with boundary layer using gambit |
March 5, 2011, 12:23 |
rohitjvbibin
Rep Power: 16 |
I have a model of a helix with rectangular crossection. I have applied boundary layer to the four required faces using the parameters below. After that i applied the edge mesh and face mesh. When applying the face mesh face 4 and 12 of the geometry contains 4 skewed elements. If i continue further I am sure to end up with a very bad mesh.
The parameters are: SOFTWARE: Gambit 2.3.6 Boundary Layer First Row: 0.001 Growth Factor: 1.2 Rows: 2 Depth: 0.0022 Internal Continuity: ON Wedge Corner Shape: ON Transition Pattern: 1:1 Faces: face 1,2,4 and 12 EDGE MESHING Interval Size: 0.5 FACE MESH Tri-Pave Interval Size: 0.5 The file is located at http://www.sendspace.com/file/rb4yyq Kindly help me out with this project. I need it as soon as possible. |
March 8, 2011, 08:27 |
Maxime Perelli
Rep Power: 41 |
*on faces 1 & 2, set all vertices as END (Mesh / face / Set Face Vertex Type )
* Splitting your domain into subdomains would help, and you could handle your geometry with hexa
In memory of my friend Hervé: CFD engineer & freerider |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 14:47 |
GAMBIT problem with 3D Boundary Layer when meshing | Anthony Haroutunian | FLUENT | 2 | March 26, 2008 03:02 |
Boundary Layer with Tet mesh | Josh | FLUENT | 0 | February 9, 2007 02:40 |
Gambit: face mesh starts at edge, not boundary lr | Chris Bailey | FLUENT | 0 | December 5, 2005 14:50 |
help for Gambit: 2 edges + 1 boundary layer | Peter | FLUENT | 0 | August 9, 2002 20:41 |
