Subtract fluid volume to simulate projectile?
Old   March 4, 2011, 19:08
Default Subtract fluid volume to simulate projectile?
Nick Smith
mrnsmith is on a distinguished road
I need to simulate a projectile in a cylinder fluid volume. I make a cylindrical fluid volume and then subtract the shape of the projectile correct? How do I do the subtracting part?
mrnsmith is offline   Reply With Quote
Old   March 7, 2011, 04:31
AB
BrolY will become famous soon enough
Which mesher do you use?
Do you want to do hexa or tetra mesh ?
BrolY is offline   Reply With Quote
Old   March 9, 2011, 23:06
Nick Smith
I am not sure which mesh I want to use... does it matter at this point or can I wait to fool around with that once I get to the meshing step.
I was told I make a cylindrical fluid volume and then delete from it the shape of my projectile. Is that true at least? lol thanks
Old   March 10, 2011, 03:45
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
With Gambit: create your cylinder (volume), create your projectile (volume)
Substract projectile from cylinder
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   March 10, 2011, 04:26
AB
With ICEM :
If you use tetra mesh, then put a material point inside your cylinder. If the projectile geometry is closed, it would not mesh the inside of this projectile.
If you use hexa mesh (blocking), then "cut" the shape of the projectile, and delete the blocks inside it.
cylinder, fluent, fluid, subtract, volume
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
Volume of Fluid and Level Set Huckleberry Finn Main CFD Forum 2 November 29, 1999 16:17
Help With Modeling A Projectile Fluid In Flight. Dzeff G. Main CFD Forum 0 December 10, 1998 22:24
