[GAMBIT] Boundary Layer without using Cooper scheme
Old   March 4, 2011, 06:25
Default Boundary Layer without using Cooper scheme
Lilly is on a distinguished road
Dear all,
does anybody know, whether it’s possible to create a boundary layer at the inner wall of a geometry, if I am not using the Cooper scheme to create my volume mesh? My problem is: I want to mesh the geometry of a vessel having a bifurcation. At this I want to create a boundary layer of hexahedral elements, because I need a good spatial resolution close to the wall. Afterwards I would like to fill up the rest of the geometry with tetrahedral or unstructured hexahedral elements. Unfortunately gambit refuses to mesh the surface via “Quad Map” or “Quad Submap” and due to the bifurcation I cannot use the Cooper scheme. Does anybody have an idea how I can get such a hexahedral boundary layer by using Gambit or Tgrid?
Thanks a million,
Lilly
Lilly is offline   Reply With Quote
Old   March 4, 2011, 10:15
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you can mesh your surface with tri, and your BL will be made of wedges.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   March 9, 2011, 10:07
Default just tets in volume
Thank you for your help!
I tried to do so, but unfortunately the Boundary Layer only exists on the surface and the volume is filled up just with tets in this case...
Do you have any idea what I did wrong?
Thanks a million,
Lilly
Old   March 9, 2011, 10:10
-mAx-'s Avatar
Maxime Perelli
post pictures
Old   March 9, 2011, 10:48
Default pics
I attached two pics that I shot in the "Examine Mesh" mode.
Thank you!
Lilly
Old   March 9, 2011, 11:29
-mAx-'s Avatar
Maxime Perelli
where did you apply the BL?
Old   March 17, 2011, 16:14
I see:I have to attach the Boundary Layer to the wall (face) of the geometry and not to the inlet and outlet edge.
It's working perfect now.
Thanks a million for your help, mAx!
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Turbulent Boundary Layer on a Flat Plate Hoshang Garda FLUENT 1 November 27, 2013 11:24
Boundary Layer mahadevan.swamy FLUENT 1 June 29, 2009 09:10
Correct way to generate grids for boundary layer quarkz Main CFD Forum 5 November 24, 2006 00:25
can fluent capture BOUNDARY LAYER of POROUS zone? Alex FLUENT 0 April 22, 2006 08:14
