[ICEM] Problem with parallel edges in ICEM
Old   February 25, 2011, 04:54
Default Problem with parallel edges in ICEM
Michal
Twix is on a distinguished road
Dear all
I have a question. How can I change bunching on some edges shown bellow, because when I try to do that I can’t and get this message.
“User error: cannot reduce the number of intervals to less than 7 because of the number of blocks”
Another question. Is it possible to manually change/disable these edges marked with red in such a way that ICEM will not see them as parallel? In other words, the node number on the left on will be 2 and on the right one let’s say 4. However, the nodes number on edge 1 and edge 2 must be equal.
Twix is offline   Reply With Quote
Old   February 26, 2011, 07:36
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Mapped blocks must have the same number of nodes on opposite sides by definition... If a mapped block is next to seven mapped blocks, then there are seven "implied splits" and the node count can't fall below the number of implied splits... I usually extend splits so these implied splits are visible and controllable, then I merge output blocks at the end...
The only way to have different node counts on opposite sides is to change the type of block to free or swept (instead of mapped). You can do this under Edit Block...
PSYMN is offline   Reply With Quote
Old   February 28, 2011, 02:44
Michal
Thank you for your reply Simon
I thought that it is impossible. I will try to extend splits as you suggest.
Regards
Old   November 21, 2015, 09:30
Default How can i make an edge parallel to the curve ?
anand darji
ananddarji is on a distinguished road
i have a curvature and i want to make an edge parallel to this curvature at some particular distance, how can i do this ?
ananddarji is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Problem with Fluent Parallel DarrenC ANSYS 0 October 27, 2009 06:38
[ICEM] Problem on ICEM. Eduardo ANSYS Meshing & Geometry 1 October 5, 2009 11:52
Problem on Parallel Run Setup Hamidur Rahman CFX 0 September 23, 2007 18:11
parallel UDF problem kerem FLUENT 2 June 20, 2006 07:56
