February 21, 2011, 02:06 |
Ansys 12 Error
Rep Power: 16 |
Recently I have installed the new version of Ansys, 13. When I want to run Ansys Workbench I get the Send/Don't Send error. The same happens when I want to uninstall it. How can I fix this?
N.B.: I am using a Toshiba Laptop with Windows 7 x64 which could ran just fine Ansys 12. Thank you. LE: I have resolved the problem. After the clean install of Windows 7, I installed de display drivers and so appeared the incompatiblity which caused Ansys to crash. After unistalling the display drivers manually installed, Ansys just works fine. Last edited by Secu; February 21, 2011 at 07:34. |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 08:43 |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 19:54 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 09:43 |
[Netgen] Installation of Netgen in SuSE Linux 92 | edvardsenpriv | OpenFOAM Meshing & Mesh Conversion | 23 | January 16, 2009 07:12 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 06:07 |
