[ICEM] Geometry in ICEM CFD
Old   February 20, 2011, 08:48
Default Geometry in ICEM CFD
DaIN is on a distinguished road
Hi guys,
I am trying to create a mesh in ICEM 12.0 to be used as input file for KIVA-3V. I am experiencing some problems once KIVA reads in the mesh and I am checking out all the steps I followed to find the mistakes I made.
The mesh is a cylindrical mesh with a central circular region on the bottom surface that will be setup as inflow.
The problem I might have with the geometry is that once I apply "Build Diagnostic Topology" I don't get all the lines in red as may seen in the picture.
Do you guys think that when some parts of the geometry are in blue, it is because something went wrong and everything should be in red??
Thanks a lot,
DaIN is offline   Reply With Quote
Old   February 21, 2011, 09:28
Default Multiple Edges.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Blue is a multiple edge... Along those edges you have 3 or more surfaces meeting. In your case the surface of the smaller inner cylinder meets with the two end surfaces (one inside and one out).
It may be fine if that was your design intent, but you should at least be aware of it. Did you intend to have two volumes separated by that inner cylinder surface?
Simon
PSYMN is offline   Reply With Quote
Old   February 21, 2011, 10:49
Hi Simon, thank you very much for your quick replay
No, actually, the point of having the inner region (cylinder) is only in order to include a Boundary Condition at the bottom and top plane. I just need to have one volume to include the whole domain.
What I am thinking now is that perhaps I don't need that surface anymore and I can work without it. I thought that I needed that inner cylindrical surface to split the initial block by O-grid, but I have just found out the inner block of O-grid does not need to be assigned to any edge, O-grid only requires the outer edges to be assigned, am I right?
Thanks a lot
daniel
Old   February 21, 2011, 11:23
PSYMN's Avatar
Simon Pereira
Right... Ogrid doesn't need any geometry to hang on. It scares me to think how hard it would be to use if I also had to chop up all my geometry... (It would be like other meshers !)
You can delete that inner cylinder and proceed from there.
Old   February 21, 2011, 11:42
Ok that's brilliant, thank you
On the other hand, for the geometry I specified above I would like to use two O-grids, one for the annular region and one for the inner circular region.
As far as I understand, you don't need special treatment at the interface between blocks which conform the O-grid, but what about in such a case that you have two O-grids?
Do you know whether I will need any special consideration at the interface between the first and second O-grid??
Thanks a lot,
daniel
Old   February 21, 2011, 12:47
Default Nested Ogrids.
PSYMN's Avatar
Simon Pereira
It is not problem to nest ogrids (one inside the other or part of another or overlapping) without any special treatment.
Old   February 21, 2011, 12:49
that's great!
Thank you very much
daniel
Old   January 3, 2012, 12:32
Post examples for kiva 3V or kiva 4.
ninguna
mel021184 is on a distinguished road
Hi, I'm working with kiva 3V.
I need examples for kiva 3V or kiva 4.
non engine application.
someone who can help me?
someone who has worked with kiva 3v or kiva4?
I'm trying to simulate a spray impacting on a surface.
mel021184 is offline   Reply With Quote
[ICEM] Problem with volume mesh in ICEM CFD kolapoasafa ANSYS Meshing & Geometry 2 September 16, 2011 04:54
Dimension conflict between icem cfd and fluent highhopes ANSYS Meshing & Geometry 1 September 9, 2011 12:07
ICEM CFD to CFX geometry and mesh Luca CFX 6 February 4, 2010 17:31
ICEM CFD Modules Boris FLUENT 1 March 12, 2004 15:37
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
