[ANSYS Meshing] Import ".dbs" into Ansys 13.0
Old   February 16, 2011, 14:18
Question Import ".dbs" into Ansys 13.0
Antallo
antallo is on a distinguished road
I'm a student. When I import ".dbs" file into ansys 13.0, are there some problem?
I mean about a problem like import file from cad? Can I to starting to work to create a mesh without any problem?
antallo is offline   Reply With Quote
Old   February 17, 2011, 02:58
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Are you using Gambit?
If yes, then I assume you need to import a mesh (*.msh) from Gambit.
Maybe it is now different in Ansys, but for sure you had to import a *.msh file earlier with Fluent (and not a *.dbs)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 17, 2011, 14:33
Default Gambit Geometry...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
ANSYS (Workbench DM, ANSYS Meshing, etc.) can now read in a Gambit Geometry file, but only the real portion (the ACIS part), not the virtual geometry stuff...
PSYMN is offline   Reply With Quote
import
How I could import Ansys mesh into CFX? mahdi57 ANSYS Meshing & Geometry 8 August 9, 2013 05:49
Can I import complex geometry into Ansys Multiphysics? mikejost ANSYS Meshing & Geometry 1 December 5, 2010 21:06
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
tgrid import from Ansys ACHILLEAS TSOMPANOS FLUENT 0 November 23, 2006 10:24
problem in import ANSYS mesh sheryl CFX 2 April 30, 2005 22:30
