[ICEM] ICEM prism layer results in Fluent NULL pointer cells |
February 16, 2011, 12:09 |
W.N. Anderson
Rep Power: 16 |
Good Evening.
I have a solid hollow sphere (part name=SPHERE), around which a 10 layer prism mesh is wrapped (prism volume part name=BL_SPHERE, top part name=TOP_SPHERE). Around the sphere's boundary layer (or, surrounding the top of its prism mesh) is a normal tetrahedral mesh (part name=FLUID). Now, when I read this mesh into fluent, I received the following error: Back in ICEM, if I only show the part TOP_SPHERE, containing the top of the prism mesh, I notice that it has holes in it, which are likely to blame for the NULL pointer error. Any idea how i can repair this or have ICEM make a better prism mesh? Here is the image of TOP_SPHERE i guess i could have cropped that image.... |
February 17, 2011, 12:22 |
Simon Pereira
Rep Power: 47 |
No idea why you got an incomplete top layer, but you can fix it with the "uncovered faces" check. (Edit Mesh => Check Mesh)
But more to the root of your problem... Should the tetras and Prisms be in the same fluid? You shouldn't need a top part or prism part at all. By default it would have put the prism in the same part as the tetras and you wouldn't have needed those shells between them at all. You can edit your way to this by right clicking on TOP_SPHERE in the parts branch and deleting it. Then right click on the FLUID part and Add to Part, then Select the second to last icon in the selection tool bar (All Volume elements). regards, Simon |
February 17, 2011, 14:29 |
W.N. Anderson
Rep Power: 16 |
I've tried to repair using the "Edit mesh -> uncovered faces check" but I've so far had no luck. I'm learning that the prism mesher (in conjunction with surrounding tetras) occasionally requires more computer than my laptop can handle, so maybe its some sort of incomplete mesh due to lack of computational resources. I will try with more horsepower and RAM and report back.
Why do I need distinct "TOP_SPHERE" and "BL_SPHERE" parts? Because these regions will be treated as rigid bodies (albeit "rigid fluid entities") by fluent in a dynamic mesh computation. The prism mesh surrounding the sphere shall retain its good boundary layer resolution, regardless of what fluent's dynamic remesher may do with the tetras throughout the domain. Best Regards. |
February 17, 2011, 16:30 |
Simon Pereira
Rep Power: 47 |
Uncovered faces should always find volume elements in different parts adjacent to each other... And prism should not write out something incomplete, even if it ran out of memory.
Maybe run a cut plane thru that area where the prism top is missing and see what is going on. |
February 19, 2011, 11:44 |
W.N. Anderson
Rep Power: 16 |
Thanks Simon. I took a look at some cut planes which you recommended.
Maybe this is helpful for people who encounter the rare combination of elements leading to those 4 holes in the prism layer top. I had a mesh density with 4 points positioned unfortunately close to the location of the top of the prism layer. The holes which I had in the top_sphere shell surrounded the locations of those points on which the mesh density was based. These 4 points interfered with the creation of the prism layer. The density points are now moved away from the sphere and now all is fine. The prism layer top has no more holes in it. Thanks and Regards. |
February 19, 2011, 12:17 |
Delete those points...
Simon Pereira
Rep Power: 47 |
I usually delete those points after creating the density box... Otherwise nodes are forced to that location and locked. Quality suffers even if the prism layer is unaffected.
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 03:34 |
[ICEM] domain interface in ICEM for fluent | hsn | ANSYS Meshing & Geometry | 24 | November 27, 2012 16:43 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
Different Results from Fluent 5.5 and Fluent 6.0 | Rajeev Kumar Singh | FLUENT | 6 | December 19, 2010 11:33 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 00:32 |
