February 6, 2011, 04:49 |
Geometry repair
Rep Power: 17 |
I have imported a geometry (IGES file) to Gambit. Unfortunately quality of the geometry is poor. There are a lot of short lines with many points and... without connectivity. Despite fact points are located in the same location Gambit can't identify that. Is there any straight way to heal the geometry? Which tools should be used? Best regards, doodek Last edited by doodek; February 6, 2011 at 05:14. |
February 7, 2011, 02:57 |
Maxime Perelli
Rep Power: 41 |
*Choose STEP File instead of IGES (if you can)
*Else use the CleanUp Tools (check tutorial 5. Sedan Geometry-virtual cleanup)
In memory of my friend Hervé: CFD engineer & freerider |
February 7, 2011, 15:10 |
Rep Power: 17 |
Thank you for answer -mAx-.
I have imported the same geometry in STEP file, but unfortunately it is not a solution, because I have identical problem like with IGES. It is interesting. Geometry has been created in Unigraphics NX 6.0, maybe it will be easier to repair geom in NX then Gambit? What is the reason of this problem? How to avoid that during model building in NX? I have tried to use CleanUp Short Edges Tool, but it is impossible to automatic merge all edges and on the other hand I can't do this merging edge by edge manually. There are a lot of edges and in my opinion automatic repair is only way to heal geometry. |
February 8, 2011, 02:07 |
Maxime Perelli
Rep Power: 41 |
can you upload your file (step) I can check your geometry
February 8, 2011, 05:53 |
hi Doodek....I think Max answered you question...Since I use GAmbit last 4 years ..I also do same way...if still u face problem...just clean that in gambit or use NX to Gambit connector tool...
February 10, 2011, 15:42 |
Rep Power: 17 |
Thank you for answer. I have solved the problem.
" your geometry has a hole. Do you want to repair it?" | moca | ANSYS Meshing & Geometry | 2 | February 14, 2018 01:15 |
ICEM --- question about repair geometry | zhaohui | ANSYS Meshing & Geometry | 1 | April 21, 2010 19:54 |
repair the geometry in the ANSYS-ICEM | feixiangniao | ANSYS Meshing & Geometry | 3 | March 31, 2010 06:53 |
how to repair geometry by another way | Priscila | CFX | 4 | August 2, 2007 12:43 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 05:31 |
