[GAMBIT] Meshing multiple 3D regions
Old   February 4, 2011, 09:45
Default Meshing multiple 3D regions
Santiago
gascortado is on a distinguished road
Hi, I'm trying to generate a mesh for an LES. The problem consists of having a plate inside a boundary layer. What Im trying to generate is a domain in such a way that I can mesh two regions of it with different meshing caracteristics.
In the attached picture the plate is not shown but it will be placed within the small volume. I want to mesh the small volume in a particular way and then the outer volume (formed by the outer boundaries and the small volume) in a different way.
I tried setting it up so that the small volume had a void inside (plate), and then the outer volume had a void that was the inner volume (containig the plate also). This way I get to mesh the two regions independently but, the meshes are not connected at the interface. Its like having two completely independent meshes.
If anyone know have to set something like this please let me know. thanks
gascortado is offline   Reply With Quote
Old   February 7, 2011, 02:34
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
connect all your surfaces
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 7, 2011, 13:12
Santiago
Thanks. I realized that shortly after. It works.
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
[snappyHexMesh] Meshing multiple blocks Hanno OpenFOAM Meshing & Mesh Conversion 3 February 17, 2011 13:14
Meshing Multiple Domains at Once ! rvallejo ANSYS Meshing & Geometry 1 June 19, 2010 22:49
[Other] Importing regions from 3rd party meshing programms suitup OpenFOAM Meshing & Mesh Conversion 1 November 10, 2009 10:40
Multiregion meshing with interface in between regions bhaskar STAR-CCM+ 2 June 23, 2009 07:06
