simulating 2D airfoil mesh in CFX
Old   February 4, 2011, 06:37
Default simulating 2D airfoil mesh in CFX
Irfan
iffy is on a distinguished road
I need to calculate boundary layer characteristics for 2D airfoil. For this I made 2D mesh in ICEM CFD (exactly following Simon's tutorial). As CFX cannot handle 2D so I tried to convert it to 3D. I have read previous threads regarding how to do this. I have tried following 2 ways.
1) converting mesh file into Fluent output file. This way works to some extent but when I open this fluent mesh file into CFX, I cannot see some of the boundaries in CFX. I defined inlet, outlet, wall, top, bottom etc in ICEM CFD and when I open mesh file in CFX I can only see some of the boundaries there not all of them. Can anyone here has some idea about the reason for this and how to handle this?
2) I also tried extruding the 2D mesh by one cell to make it 3D. Although I define the curves in the parts which I want them as boundaries (the curves are associated to the edges) but still in CFX, I cannot see any boundaries where I can put the bocos. Can anyone knows something about this.
I will really any suggestion/advice regarding this.
Regards,
Irfan
iffy is offline   Reply With Quote
Old   February 4, 2011, 08:15
saisanthoshm88 is on a distinguished road
Well this question has been asked for a number of times on the forum before. you need to check the associations made once again because the line elements are generated only on those edges which are associated to the geometry you might have made the associations correctly in the begining but there can be some disassociations occuring when you do operations like split edges etc.., so to be sure of the associations have a look at the line elements before exporting the mesh just turn on the line elements but turn off the shell elements in the model tree to do that.
Best regards,
Santhosh.
saisanthoshm88 is offline   Reply With Quote
Old   March 3, 2011, 04:59
Ugly Kid Joe
vmlxb6 is on a distinguished road
Are you following the tutorial on you tube ???? Then you must be making a silly mistake here or there ??????? I have tried it and it works well.
vmlxb6 is offline   Reply With Quote
Old   March 8, 2011, 12:35
lenovosk is on a distinguished road
I agree with saisanthoshm88.
lenovosk is offline   Reply With Quote
Old   March 9, 2011, 03:53
Irfan
Hi Santhosh, vmlxb6 & Lenovosk:
Thank you for your replies and useful suggestions. I managed to solve this problem. There was some problem with the geometry association as Santhosh pointed out.
But now I come across another problem: I want to determine laminar to turbulent transition for an airfoil for which I need the mesh to be orthogonal. Somehow I could not make the mesh perfectly orthogonal. I have tried smoothing option but it always distorts the mesh.
I will appreciate if anyone here can provide some suggestion to resolve this.
Regards,
Irfan
Old   March 9, 2011, 04:10
Default @ iffy
Ugly Kid Joe
One way I know is to specify the first layer distance from the boundary wall. It also makes sure that the first set of elements or BL is orthogonal. In the tutorial provided by Simon on you tube, When he does smoothing, he specifies the orthogonal distance first.
Am I on the right track ??? Is this what you wanted ???
Old   March 9, 2011, 04:53
Irfan
Actually I have tried this option, it works to some extent. It makes first layer in the boundary layer region orthogonal but it distorts the mesh everywhere around. I am looking for some other option/function in ICEM.
Old   January 24, 2017, 04:05
JEEVAN
JEEVANSADALGE@GMAIL.COM is on a distinguished road
i am also facing the same problem while doing meshing to my 2d airfoil
can anyone suggest the solution??
orthogonal elements to airfoil
JEEVANSADALGE@GMAIL.COM is offline   Reply With Quote
2d airfoil, 2d mesh into 3d, cfx
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
Mesh Adaption in CFX. Kushagra Mittal CFX 1 August 31, 2011 09:17
Mesh Airfoil in ICEM student123a ANSYS 3 January 24, 2010 12:54
CFX mesh & ICEM mike CFX 3 April 27, 2006 16:27
convert FLUENT mesh file to CFX mesh file?? frederic felten FLUENT 5 December 6, 1999 10:32
