[Other] exchange of parameter values between TurboGrid and DesignModeler in Workbench |
January 17, 2011, 11:18 |
Rep Power: 16 |
I declared parameters in TurboGrid and DesignModeler too. They appear in the parameters workspace in Ansys Workbench, so everything is fine. Now, how can I assign a DesignModeler parameter value with a TurboGrid parameter value? If I write its name in the so expression field it does not recognize it...see attached picture The question could be more general how to exchange values of parameters between any Ansys components (can be DesignModeler, Fluent, CFX, Mechanical, TurboGrid etc.)? Thanks for any help in advance! |
February 18, 2011, 09:57 |
Use the Parameter ID, not name.
Simon Pereira
Rep Power: 47 |
Maybe it could be more flexible... I will see what we can do.
In the mean time, you don't type in your name for the parameter (TT2), you type in the Parameter ID, (P11). So, in your expression for P10 (aka BB), you should type in "P11". The result will be that P11 will always have the same value as P10, and that P11 will be the source (as P11 changes, P10 will match it) Best regards, Simon Last edited by PSYMN; February 18, 2011 at 13:44. |
February 21, 2011, 16:12 |
Rep Power: 16 |
yes with the Pxx name I can assign another parameter, but the frustrating things are the dimensions. DM parameters are dimensionless by default and can not be changed even with a script (tried that), while TurboGrid parameters will aways have a unit (dimension). So it is not that easy, but I solved that too by non-dimensionalising Turbogrid parameters. So I wish parameters could be more flexible to assign and Pxx names are hard to follow as that can not be changed and Pxx is not an informative name. Also it would be nice if parameters coming from any program would all either be dimensionless or with dimension. These could have saved me some time and hassle...but anyway could find a way to circumvent these... But thanks for the post and best regards, lazlow |
parameter set, parameters workspace |
