January 16, 2011, 17:56 |
Basic Question - Double Mesh's Cells
Hello there,
this is my first post to this wonderful forum (gj guys), so you can assume I am pretty amateur with CFD. I am currently simulating a case in ANSYS FLUENT, but here is my problem. The mesh was already given to me and is about 100.000 tetrahedral cells. What I would like to accomplish is to change the number of cells to double (200.000) or half (50.000) just to see how the converge will change. The problem is that I don't know the way. Should I do it with GAMBIT or TGRID? Is there a good guide/tutorial to follow or a single command in any of these programs for a job like this? Is there a way to change the mesh with the already boundary conditions along with it (maybe immediately with FLUENT)? The PC I am working with has the Intel i7 920, 6GB RAM, and the programs are of these versions FLUENT v.12.0.1, TGRID v.3.4, GAMBIT v.2.4.6, Windows Professional 7 x64. Thank you in advance |
January 17, 2011, 02:47 |
Maxime Perelli
Rep Power: 41 |
You will have more control by refining (coarsening) your mesh within Gambit.
If you have the dbs file, just open it, and remesh your surfaces (if your model is 2d) or your volumes (if your model is 3d) If you don't have the dbs file, you can import the mesh file, but you won't have access to any volume-suface decomposition since Gambit will import one surface(2d)-volume(3d).
In memory of my friend Hervé: CFD engineer & freerider |
January 17, 2011, 09:18 |
Dear Max, first of all thank you very much for you quick reply. Although I would like to ask how is it possible to just double the cells of my mesh without changing the boundary condition? Are the boundary conditions includen in the .mesh or in the .dbs? I don't have the .dbs file! And one last question: Is it possible to do for me to do what I asked for with TGrid?
January 17, 2011, 09:25 |
Maxime Perelli
Rep Power: 41 |
I assume you can do that with T-Grid, but no idea howRegarding Gambit, just import your mesh, and remesh.
It won't affect the boundary conditions (yes they are included in the .msh file)
convergence, double cells, mesh size, meshing |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
Question about ghost cells in parallel processing | vishwas | Main CFD Forum | 3 | March 12, 2006 22:46 |
double cells problem | Nirmal Kumar Pathak | Siemens | 1 | October 31, 2005 13:36 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 01:32 |
A Basic Question on ducted Flows! | CFD User | Main CFD Forum | 4 | January 8, 2005 07:17 |
