December 24, 2010, 07:14 |
ANSYS CFD Split block question
Rafael
Rep Power: 17 |
Hello
I have a big mesh and i want to split only a vertex without affecting the closer one. See the picture Thank you very much for your work Last edited by cfdonlinederafa; December 24, 2010 at 07:36. |
December 27, 2010, 17:17 |
What do you actually want it to do?
Simon Pereira
Rep Power: 47 |
There are a variety of commands, I am not sure about your final goal...
Perhaps you are looking to split back face? Then try "split face" and pick at that point location. Or maybe you actually want to split the vertex to create a wedge block...? Then try split vertex. It will actually create a new index between either side of that current vertex... If you split block it will go thru the whole block and give the split you are seeing. |
[blockMesh] FOAM FATAL ERROR: Inconsistent number of faces blockMesh::createMergeList() line 193 | Hengel | OpenFOAM Meshing & Mesh Conversion | 7 | November 15, 2021 23:56 |
[blockMesh] FOAM FATAL ERROR: Inconsistent number of faces blockMesh::createMergeList() line 193 | Hengel | OpenFOAM Meshing & Mesh Conversion | 0 | September 15, 2010 09:34 |
Question about Table applicaiton. | universez | OpenFOAM Running, Solving & CFD | 0 | January 12, 2010 21:31 |
Multiblock: one block to many block interface | kpv | CFX | 0 | December 9, 2007 20:53 |
Number of nodes on block. | Felix | CFX | 0 | October 24, 2007 23:26 |
