units of geometrical parameters lost
Old   December 15, 2010, 04:53
Default units of geometrical parameters lost
SoobY is on a distinguished road
hi,
i think this is a rather common problem but i couldnt find a solution yet. I would like to make a thermal analysis where i have to vary a couple of parameters. the result should be the specific thermal resistance of my geometry. therefore, i need to multiply and add a couple of parameters in my parameter set in Ansys workbench.
p r o b l e m:
if I click the small box in the design modeler to make a dimension to be a parameter, the units are not transfered to the parameter set. however, the units of parameters in my steady-state thermal block are transfered to my parameter set. then, if i add or substract parameters in the parameter set using parameters from both blocks, it happens that the units are incorrect although the formula actually is correct. ansys states "Invalid operation:
1316 [kg^-1 m^-2 s^3 C] + 0.0005555 [kg^-1 s^3 C]"
is there some way to exclude the units like in MATLAB or what can i do to enable the units of my design modeler?
thanks a lot for your help
SoobY is offline   Reply With Quote
Old   December 20, 2010, 17:23
Default Work arounds
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
We will work on making the function editor more tolerant of addins that don't include parameters.
In the mean time, here are 2 possible work arounds...
If you are using R13, you can insert an EXCEL system on the desk top. This system could take in the parameters and do your function without worrying about the units... it would produce an output parameter as your result which you could then optimize by.
You could also add units to your function... for instance, if X is a length parameter that should have been in mm, you could do the expression as:
Y = (5 mm) + (X * (1 mm))
PSYMN is offline   Reply With Quote
Old   January 10, 2011, 04:58
thanks for your advice. I was wondering how to add units to my function. so i had to do it using excel.
UDS source term units Ale FLUENT 3 March 29, 2017 08:08
Mass transfer units in fluent nite_surfer FLUENT 0 July 12, 2007 13:51
New to CFX-need explanations about mesh parameters Cyril CFX 3 November 24, 2006 07:33
Units for Contaminant Concentration Rob Phoenics 1 March 30, 2005 11:06
To dimensionalize or not to dimensionalize !! tolani owosina Main CFD Forum 8 November 13, 1999 14:45
