mesh generation for in-cylinder fluent simulation
Old   December 14, 2010, 03:34
Default mesh generation for in-cylinder fluent simulation
henry clarke
hennas is on a distinguished road
I was wondering whether anyone can provide me with some general advice on the best approach for creating a mesh to use for a dynamic engine cylinder simulation. I know I need to use a dynamic mesh, but it is not really clear where I do this.. Do I just create a normal mesh using design modler and meshing and then define the cell layering, sliding interfaces, and remeshing in fluent afterwards - or must I do something special in meshing? And, does the inlet valve need to be defined as some sort of body, or just a void in the mesh?
I am trying to do this in 3D, partly because I will be needing to go 3D eventually anyway, but also because I have no idea how you would create a 2D mesh - does anyone know of any 2D meshing tutorials for the Ansys (11) meshing application.
Thanks!
hennas is offline   Reply With Quote
Old   December 21, 2010, 13:46
Default Ic3m
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
ANSYS does have a vertical application for this called "IC3M" (in cylinder moving mesh model)
It automates the setup and meshing process by asking for things like which parts are the valves and what are the valve lift profiles, etc.
I have not been involved with it for some time and I know they are refactoring it (so what I know is out of date), but it is worth a look rather than re-inventing the wheel or setting everything up manually.
Best regards,
Simon
PSYMN is offline   Reply With Quote
Old   May 31, 2011, 16:08
Default Help !
majid
kaparzo-shb is on a distinguished road
hi,
I am preparing a job in the si cylinder but i don't have the 3d geometry for simulate them in fluent
i can't found it any were.
please if you can help !
kaparzo-shb is offline   Reply With Quote
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
Exporting structured mesh from ICEMCFD to Fluent? jeevan kumar FLUENT 1 January 23, 2012 12:21
Moving mesh in Fluent fivos FLUENT 0 April 2, 2010 10:45
Simulation Flow Around cylinder 3D Jwolf CFX 19 November 25, 2009 15:21
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
