Questions about ANSYS ICEM CFD tutorial
Old   December 4, 2010, 21:52
Default Questions about ANSYS ICEM CFD tutorial
pablo
pquispea_m5 is on a distinguished road
hi,
i have a few question about the manual in section 3.7.2 "Tutorial Opera M6 Wing with 0.54 M":
1) In the visualization of result iget pressures over the wing. how can i get the dimension of this values? Are they in Mpa in this case?
2) If i want to get stresses and deformations on wing (from root to tip), how can i export the pressures values (i understand it as loads) to ANSYS Workbench? so i assign boundary conditions and materials properties to calculate it. Or is it calculated in ANSYS ICEM CFD directly? Thanks
Greets,
Pablo
pquispea_m5 is offline   Reply With Quote
Old   December 5, 2010, 16:24
pablo
Any answer please.
grts,
Pablo
Old   December 5, 2010, 16:30
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
That tutorial shows post in ICEM CFD Visual3 Post... It is possible to map these results to FEA output. I made a tutorial for that years ago, but I just did a search and couldn't find it.
I recommend you use CFD Post in ANSYS Workbench which makes it much easier. There are a number of new tutorials explaining the process.
Sorry, I have switched to CFD Post several years ago and don't have a fresh memory about Visual3...
Usually, there is a legend to help you interpret the colors. You can also draw lines to use as the Xaxis of a 2D pressure plot, etc.
PSYMN is offline   Reply With Quote
Old   December 5, 2010, 16:58
pablo
thanks for your answer simon. we are in contact
grts,
Pablo
Import Mesh from ICEM CFD to CFX Andre Almeida CFX 16 April 19, 2016 04:42
[ICEM] what does the different ANSYS ICEM and ANSYS Workbench? agungwp ANSYS Meshing & Geometry 8 April 12, 2016 05:51
Opening ICEM CFD directly from ANSYS matheusguzella ANSYS Meshing & Geometry 6 February 22, 2010 12:27
Free UK seminars: ANSYS CFD software Gavin Butcher CFX 0 November 23, 2004 10:13
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
