[ICEM] hexa meshing prob
Old   November 12, 2010, 07:15
Exclamation hexa meshing prob
wadoud
wadoud31 is on a distinguished road
i am new to this forum and I need help, I have a problem with hexa meshing
wadoud31 is offline   Reply With Quote
Old   November 12, 2010, 12:36
john
johnp is on a distinguished road
Welcome. You will need to provide more details of your specific problem in order to get any meaningful responses.
johnp is offline   Reply With Quote
Old   November 14, 2010, 22:22
Question
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
PSYMN is offline   Reply With Quote
Old   November 17, 2010, 09:21
wadoud
Thank you I want to study the flow in a channel cross dawn, but I have problems meshing (hexa) here is the geometry
Old   November 17, 2010, 10:11
john
The geometry doesn't look too difficult to me. There is an excellent tutorial on youtube that will get you started. It's in three parts, here's the link to the first:
http://www.youtube.com/watch?v=tYrbScUH9RE
Old   November 17, 2010, 12:01
Default more specifically...
PSYMN's Avatar
Simon Pereira
For success with this sort of model, you should pay close attention to the options for "shifted periodic" if you are modeling the tip gap. However, if you are not modeling the tip gap (2D certainly does not include the tip gap), try modeling the channel instead of around the blade (to avoid much of the periodicity).
You can find info about that in part 1 of the you-tube mini-series or by searching those terms in CFD-Online.
Best regards,
Simon
Old   November 18, 2010, 08:16
wadoud
thank you for your kindness, I saw the video but I could not do better now, the mesh quality is very poor, so I can send you the geometry and try to make the mesh, I'd be very grateful
Old   November 18, 2010, 11:37
PSYMN's Avatar
Simon Pereira
I am already a little overcommitted right now. Maybe someone else can help.
Note, you still haven't even said what your problem with Hexa is...
Old   November 18, 2010, 13:15
wadoud
my problem that I can not get a good mesh with refinement on the walls like this example, thank you my friend
Old   November 18, 2010, 13:53
john
Can you post an image of the blocking strategy you are trying? This will make the problem easier to diagnose.
Old   November 18, 2010, 14:06
wadoud
thank you for your interest in my problem, I want a mesh like this examle (aube)
Old   November 18, 2010, 14:47
wadoud
like this example
Old   November 18, 2010, 14:48
wadoud
this my blocking
Old   November 18, 2010, 15:00
PSYMN's Avatar
Simon Pereira
How about a picture that shows the problem?
Old   November 18, 2010, 15:07
wadoud
htis is the picture
Old   November 19, 2010, 15:48
wadoud
hello everyone, I'm still waiting assistance, thank you.
Old   November 19, 2010, 17:54
Default What is the problem?
  #17
PSYMN's Avatar
Simon Pereira
You need to generate an Ogrid.
GO to split blocks => OGrid and select all the blocks.
Then Select all the outer edges so Ogrid won't form there.
THen Apply.
The Ogrid will form around the remaining edges that you did not select (the edges around your airfoil.)
I guess I can help with this simple thing if you post the files. (*.prj, *.tin and *.blk)
Old   November 20, 2010, 05:05
wadoud
thank you simon for your advice, I try to do that but I can not,how i can send the requested file, my email: wadoud31@live.fr
Old   November 23, 2010, 12:58
Default transonic flow: experimental data of (MUR 45 of VKI CT2)
  #19
wadoud
hello everybody, I need experimental data to test MUR 45 of the geometry VKI CT2 and also the conditions of the flow (transonic flow), thank you
Old   December 1, 2010, 11:16
Thumbs down
  #20
wadoud
[ICEM] Hexa meshing of impeller and diffuser assembly Nitin Dewangan ANSYS Meshing & Geometry 14 September 13, 2016 10:41
3D wing + wind tunnel hexa structured meshing icemaniac178 ANSYS Meshing & Geometry 9 October 28, 2010 10:37
[ICEM] Hexa Meshing a helical profile Balakrshnan Ramakrishnan ANSYS Meshing & Geometry 1 August 24, 2010 11:53
Hexa Block meshes in ANSYS Meshing? siw ANSYS Meshing & Geometry 3 July 31, 2009 11:40
Hexa meshing or Tetra meshing??? NITIN DEWANGAN CFX 5 August 5, 2008 10:59
