November 1, 2010, 14:45 |
Making wing geometry in Ansys 12.1
Akash
Rep Power: 16 |
Started working on designing an F1 front wing on Solidworks last year but now have to do it using Ansys 12.1's design modeler. I cant import the solidworks geometry in due to install errors.
Basically how can i make a 3D wing. Is there a way to extrude a curve or import in a curve file and then convert it into a sketch like i can do in Solidworks? Any help would be good as well as if there are better ways to making a wing using the modeler. Thanks |
November 1, 2010, 17:35 |
#2 | ||
Rep Power: 17 |
Importing a points file can be done under the point feature. Or you could create points using jscript from a file. An easy way of doing the latter is to create a few points and then in the file menu ask it to "write out script of active plane" (or something similar can't exactly remember the wording). |
March 7, 2011, 12:24 |
Rohit Vasudevan
Rep Power: 15 |
@Akash
I'm doing a similar project... I seem to be having the same problem where i can't seem to extrude a 3D curve... But i did import the curve into ansys... vut cant seem to do anythin with it... U basically import the data points into ansys in a specific format.. X, Y and Z triples basically... |
September 26, 2013, 15:46 |
Pjotr
Rep Power: 14 |
hi all, i know the topic is not that new
but i wrote a tutorial -ANSYS DesignModeler: import XYZ points from file, make splines, surfaces and body. + Meshing cheers |
ansys 12.1, design modeller |
Evaporation model in ansys Fluent 12.1 | oldisbest | Fluent UDF and Scheme Programming | 12 | March 26, 2020 10:11 |
Ask for Wing LANN 's Geometry file | ccyx | Main CFD Forum | 2 | March 11, 2013 10:01 |
ANSYS 12.1 tutorial | katiyon | CFX | 8 | December 2, 2011 05:09 |
Delta Wing Geometry | Apurva Shukla | Main CFD Forum | 2 | May 26, 2001 08:26 |
Where to find 3-D Wing Geometry? | G.P. Xia | Main CFD Forum | 4 | May 28, 1999 11:44 |
