[ICEM] Complete beginner with ICEM
Old   October 18, 2010, 20:11
Default Complete beginner with ICEM
Donal Fitzpatrick
dfitz1000 is on a distinguished road
Hi guys, hopefully somebody can help me here.
I am a complete beginner with ICEM and I'm basically trying to teach myself how to use it which feels like I'm banging my head off a brick wall at this stage.
Ultimately I want to model a 3d wing section in SolidWorks, import it into ICEM and mesh it before bringing it into FLUENT and trying to model the flow over the wing with particular interest in the wing tip vortices generated.
I have some tutorials that I have worked through but have been no help to me as they are just "walkthroughs" and nothing is explained. Does anybody know where I can start to learn from scratch how to mesh 3d parts.
In particular what I cant understand is how to model the flow field, i.e. how do I assign where the air will come in at the wing? Can you just model the wing alone or does it need to be attached to some wall as I have seen done on the wingbody tutorial? Like I said there's lots of tutorials but no basic explanation of the steps involved.
The wing I'd like to model is a NACA-0012 wing with no taper or twist, just a basic straight wing. The tip is flat and the trailing edge is sharp. It's a simulation of a wind tunnel test that I'm going to run.
Sorry for the long post but I really feel quite lost at this stage, hopefully some of you have been in my position at some stage and can give me some help.
Thanks.
dfitz1000 is offline   Reply With Quote
Old   October 19, 2010, 14:08
Default Tutorials...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Sure, you could model it as the wing in the tunnel (simulate the test), where you would have no slip walls, etc. Or you could go beyond the test and put a symmetry boco on the wing root wall and a far field boco on the other walls.
There are several tutorials for the wing in a box. Try to find them in the software under help => tutorials or on the customer sales portal...
Simon
PSYMN is offline   Reply With Quote
Old   October 29, 2010, 14:58
Donal Fitzpatrick
Hi Simon, thanks for the reply.
I have managed to mesh the wing section and the wind tunnel "box" around it, the pictures are attached.
Bearing in mind that my interest is in the vortices downstream of the wing I think my approach is wrong. Correct me if I'm wrong but should I be meshing the area around the airfoil and inside the wind tunnel "box" instead of the wing surfaces and tunnel walls themselves?
The thing is I can't figure out how to do that at all, does anyone have any ideas?
I know this is basic stuff but no tutorials I've been through deal with this and I'm basically teaching myself.
Thanks.
Old   October 31, 2010, 09:07
Donal Fitzpatrick
So I somehow managed to figure out how to mesh the wind tunnel box using volume mesh and it was actually pretty easy once I figured out how, it's a pity I couldn't find it earlier.
Anyway I've moved onto the analysis in FLUENT and I need help here too! I guess it's best to start a new thread in the FLUENT forum.
Old   November 2, 2010, 14:32
PSYMN's Avatar
Simon Pereira
There are tutorials, sorry you were not able to find them. If you get another chance to look on the customer portal, it may be worth your time.
I think I also posted a link to the entire 11.0 tutorial packet several times on CFD-Online...
The images you showed were very coarse and will not adequately resolve your flow... Hopefully your final mesh was finer. Also, you may want to use a density region to better resolve the flow behind your wing in order to capture the wake, etc.
Simon
Old   January 17, 2011, 14:51
Donal Fitzpatrick
Hi, my final mesh was indeed a bit finer (see the attached picture).
I'm now trying to refine and improve the mesh so that I can get the most accurate results. One thing that is immediately obvious is the mesh on the trailing edge is very poor as you can see from my original pictures. How can I improve this to give a better mesh on the TE which is sharp?
Also, is there anything else I can do to give me the best possible mesh?
Thanks.
Old   January 17, 2011, 17:22
Default Prism Wake...
PSYMN's Avatar
Simon Pereira
For this sort of configuration, I suggest that you project the trailing edge curve onto the outlet (or at least copy it back a ways), then create a surface between the trailing edge and the new curve. Lets call it "PRISM_WAKE" for fun. Build topology so the new surface gets curves on the symmetry planes...
Then go into PARAMS by Parts and flag "PRISM_WAKE" as an internal wall. Also turn on PRISMS for PRISM_WAKE.
Then Tetra mesh the model.
Set the curve parameters on the curve projected from the trailing edge curve so that it has a larger initial height than you set on the wing (this is to promote a transition in size... Make sure you don't set a prism height on the "PRISM_WAKE" surface its self.
Then generate prism and you should get something like this...
(don't forget to delete the shells in PRISM_WAKE when you are done.
Note... Hexa would still be better. I also posted a combo (Tetra/Prism followed by Tet to Hex conversion).
There are other more detailed conversations about this already on CFD-Online...
question from ICEM beginner Jiuan CFX 1 March 6, 2009 19:41
icem hexa mesh beginner icem beginner CFX 3 July 23, 2008 05:26
icem hexa mesh beginner icem beginner FLUENT 2 July 9, 2008 08:27
icem hexa mesh beginner icem beginner Main CFD Forum 3 July 9, 2008 08:08
HELP ICEM beginner degenerate edge guest7777 CFX 0 October 17, 2007 13:41
