Need some basic information for using Ansys Design Modeler
Old   October 17, 2010, 23:56
Default Need some basic information for using Ansys Design Modeler
Pradeep Maheshwari
pradeepmash is on a distinguished road
Hi
I am a new member over here. I have just started working on ANSYS 12.1 for my research work. I have created a few geometries using "Ansys Design Modeler". Now, I am facing problem in creating some small feature like through-holes on a wall etc. For example if I want to create a hole on a wall what I need is the radius of the hole and its location. Is there anyway that I can specify the coordinates of the center of the hole (x,y,z) and it will create the hole at the desired location?? Its difficult to look at the screen to find the appropriate point which is going to be the center of the hole.
Another way is creating the hole at a random place on the wall and then adjusting the location afterward. I have tried this, created holes on random locations, but I am not able to move the holes to a different location. Please guide me how to do it. It may sound a very simple problem but I do not have strong ANSYS knowledge as I am just a beginner.
Thank you.
-Pradeep
pradeepmash is offline   Reply With Quote
Old   October 19, 2010, 14:16
Default Steps...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Sure,
1) start with a sketch plane... Maybe on the surface you want to drill a hole in, or maybe in one of the primary planes.
2) Draw a circle in roughly the right place
3) Under sketch, go to the "dimension" section, and dimension the radius, the horizontal distance from some edge or axis and the vertical distance from some edge or axis.
4) Edit the parameters (R1, H1, V1) to give the right measurements.
5) Extrude the sketch using the option to remove material, etc.
PSYMN is offline   Reply With Quote
Old   October 22, 2010, 01:22
Default Thank you
Pradeep Maheshwari
Hi Simon,
Thank you very much for a quick and informative reply. With your suggestion I was able to cut holes at the appropriate locations.
I wasn't expecting such a quick reply as this was the first time when I used this forum but I found it useful.
Thanks again
Regards,
Pradeep
Old   October 24, 2010, 17:01
PSYMN's Avatar
Simon Pereira
I don't always have time for such a quick response, especially lately, but some times you get lucky...
Glad you are going again.
Simon
[Other] Connecting 3D bodies in Ansys Design Modeler chipper ANSYS Meshing & Geometry 4 January 25, 2018 10:45
Importing Points in Design Modeler danh ANSYS Meshing & Geometry 5 March 30, 2015 11:45
[Other] ANSYS Design Modeler OxIan ANSYS Meshing & Geometry 0 August 4, 2010 14:13
2-D Design Modeler Geometry - Ansys 12.0 hodeje01 ANSYS Meshing & Geometry 2 October 7, 2009 11:42
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
