ICEM keyboard problem in linux
Old   October 8, 2010, 09:09
Default ICEM keyboard problem in linux
Reine Granström
gravis is on a distinguished road
I am running ICEM 12.1 under Centos. Recently I upgraded from Centos version 4 to 5, keeping the ICEM installation.
After upgrading, the keyboard is not working properly in ICEM. I can use the key "x" to fit the screen and some similar things in the 3D view. However, the keyboard is not working e.g. for setting parameters or inside the "Open project" window.
I have tried uninstalling/reinstalling ICEM without any difference.
I would appreciate any advice.
gravis is offline   Reply With Quote
Old   October 9, 2010, 12:48
Default Open source
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Linux is open source and therefore has many flavors, etc.
It would be impossible for ANSYS to test all possible flavors so we have focused on the more stable and much more commonly used RedHat 4 and 5 and Suse 10.
Other versions may work, or they may not. But we haven't officially tested.
You are in uncharted territory.
Sorry.
PSYMN is offline   Reply With Quote
Old   October 11, 2010, 03:26
Reine Granström
Thanks for your reply.
Good to know about the other distributions, I will probably have to try them instead. I am aware of the risk taking of using a more uncommon distribution, so running into this problem was no huge suprise
Old   July 6, 2016, 13:16
Default Keyboard not working
Olli
Moelfus is on a distinguished road
Hi guys,
I know it is an old thread but I stumbled upon the same problem with ICEM 16.1 and Centos 7 and wanted to share the solution with you. To get ICEM working again you just have to unset the following environmental variables in the shell before calling ICEM:
unset QT_IM_MODULE
unset XMODIFIERS
unset GTK_IM_MODULE
To get permanently rid of it you can also add these lines to your .bashrc:
echo "unset QT_IM_MODULE\nunset XMODIFIERS\nunset GTK_IM_MODULE" >> .bashrc
Moelfus is offline   Reply With Quote
Old   February 28, 2020, 10:23
Brandon
kepler123 is on a distinguished road
unset QT_IM_MODULE
unset XMODIFIERS
unset GTK_IM_MODULE
This is super old, but thanks a ton!
kepler123 is offline   Reply With Quote
Problem with reading .cas and .msh file in ICEM CFD kbodla ANSYS Meshing & Geometry 3 March 14, 2011 16:50
problem exporting from icem to fluent jc_muaddib FLUENT 1 June 16, 2010 05:16
Icem to FLUENT problem Babak FLUENT 0 June 10, 2010 18:14
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
a problem of icemcfd in linux anne Main CFD Forum 0 March 12, 2008 05:55
