[GAMBIT] problems creating moving solid
Old   October 5, 2010, 23:28
Question problems creating moving solid
free is on a distinguished road
I'm new to the GAMBIT and FLUENT package, but I'm trying to pick up what I need to know in order to analyze the following problem:
I'm attempting to crush a small droplet of water using a solid/wall/whatever will work. The droplet sits on hydrophobic material (contact angle 180 degrees ideally) and I wish to slowly move the solid in from above to squish the droplet.
I've been trying for quite some time and researching on the web, and it seems like using layering and a moving mesh is the appropriate way to proceed, but I'm having trouble finding a clear tutorial to learn all i need to properly set up the problem.
If anyone could let me know if this method is feasible, and/or point me to a good tutorial on moving meshes that is similar to this situation, I would be very appreciative.
Thanks,
Robert Free
free is offline   Reply With Quote
Old   October 6, 2010, 02:14
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Layering, remeshing , smoothing (or even sliding mesh) depend on your geometry and also on the solid motion.
I could imagine using layering method with a translation.
There is a tutorial (layering) on the online help, but there should be also other tutorials on the fluentuser website
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   October 6, 2010, 02:24
Thank you, I will look into those. My current 2-D geometry is a simple rectangle in which I'm trying to place a smaller rectangle with the same width, so it is basically a piston. I patch the water droplet in after importing the mesh into FLUENT.
Old   October 6, 2010, 02:29
-mAx-'s Avatar
Maxime Perelli
Then you can use layering.
Check tutorial 13 "Using Dynamic Mesh" (fluent 6.3) : This is a 2d Check Valve
Old   October 6, 2010, 12:50
Is this tutorial located in the FLUENT software?
Old   October 7, 2010, 02:54
-mAx-'s Avatar
Maxime Perelli
should be if you also installed all the documentation
moving mesh, moving wall, tutorial, water drop
Moving Solid particle in a flow yigity83 CFX 13 July 14, 2009 09:48
Motion diffusivity solver has problems with patches moving toward each other bfa OpenFOAM Running, Solving & CFD 2 July 8, 2009 22:35
Solid Fluid Interface boundary problems shankara.2 ANSYS Meshing & Geometry 0 April 22, 2009 17:05
how do I get a solid volume moving? Katariina CFX 2 March 28, 2008 05:50
liquid/solide phase change problems mehdi fteity Main CFD Forum 3 September 14, 2000 22:44
