unable to attach the geometry file
Old   September 22, 2010, 09:36
Default unable to attach the geometry file
artemis
artemis64s is on a distinguished road
Hi
I have created a 3D geometry in Design Modeler, then I extracted the data as .agdp. now I am going to mesh the geometry but it fails to load the file in mesh system! the error is :
''unable to attach the geometry file''
and the meshing window is gone then,
I also extracted the geometry to .igs and also to .stp but still the same problem...
can anyone help me in that please?
Regards
Artemis
artemis64s is offline   Reply With Quote
Old   October 5, 2010, 20:32
Default The schematic can transfer the files for you...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Are you using ANSYS Meshing? Why not just connect the meshing system to the DM system on the project page schematic (just drag and drop)... That is the beauty of WorkBench...
If I am misunderstanding, please add some more details.
PSYMN is offline   Reply With Quote
Old   March 10, 2011, 15:30
Yuri Singha
yus310 is on a distinguished road
I'm having the same problem for ansys fluent 12.0. I have constructed my geometry and then when I try to update my project, it says "unable to load geometry into mesh cell... ", equally if I try to open up the mesh option, ansys fluent doesn't recognize my geometry and closes out.
Any suggestions to remedy this?
Thanks.
yus310 is offline   Reply With Quote
Old   March 11, 2011, 11:44
PSYMN's Avatar
Simon Pereira
No I am not sure where you went wrong, but it should work so I suggest you go back into DM and look at your model again... Is it corrupted in some way? Is it properly part of the project (does clicking on the geometry field open the right file in DM)? Can you post a screen shot of your project schematic so I can see how you hooked it up?
Old   March 11, 2011, 11:50
Yuri Singha
My geometry is linked to the project schematic, and when i open up the geometry in project schematic, I get the geometry (just a tube). The only thing is the mesh won't recognize the geometry. When I upload other people's geometry, still the mesh won't recognize the geometry. The geometry is 2-D, it just a rectangle turned into a surface for 2-D fluid flow analysis.
The geometry has a check in the project schematic and the mesh has a recycling like symbol.
Some suggest using CAD Configuration 12.1, etc. But I don't know if it is a licensing issue, or something else.
Thanks,
Old   March 12, 2011, 18:48
PSYMN's Avatar
Simon Pereira
I suggest you start over... Clearly something has gone wrong.
Just start over, create a new rectangle, make sure you create a surface from the sketch (did you do that?), then proceed to meshing and see what happens...
Thousands of customers do this everyday without any trouble.
Old   March 12, 2011, 20:24
sac
sac is on a distinguished road
Set the geometry type in the schematic to 2d?
sac is offline   Reply With Quote
Old   October 15, 2013, 14:31
Jackpot is on a distinguished road
I have the same problem, 2D surface with a check in the DM but with a cross in the Mesh.
When I try to open the mesh it close suddenly and ansys show the error message "unable to attach to geometry file".
Anybody has some advice?
Thank you
Jackpot is offline   Reply With Quote
Old   October 15, 2013, 18:28
I have tried to solve the trouble asked before and finally the solution was on changing the 2D surface body from YZ to XY plane.
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 08:11
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 12:47
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 05:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
