an internal error occurre in ICEM
Old   September 20, 2010, 23:23
Default an internal error occurre in ICEM
Qiulan Zeng
qiulan is on a distinguished road
Hi, everybody. Here is my problem when i tried to mesh the surface. When i finished compute surface mesh using patch dependent method I checked and found that two curves forming a sharp angle. Knowing that the two curves have no influence on connectivity between surfaces, so I wanted to delete them. By this time, a spread sheet was popped up saying "an internal error has occured: syntax error in expression 'emethod':variable references require preceding$...." What does this mean? Why it happens every time I perform this practice? What can I do then?
Many thanks!
qiulan is offline   Reply With Quote
Old   September 21, 2010, 12:06
Default Techsupp@ansys.com
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
I can't tell from here...
I suggest that any failures be reported to TechSupp@Ansys.com
Ideally you can include the case with instructions so they can reproduce it and get the same crash... If we can crash it, we can fix it.
Best regards,
Simon
PSYMN is offline   Reply With Quote
Old   September 22, 2010, 11:14
Qiulan Zeng
Dear Semon,
I have reported the failures to TechSupp@Ansys.com. Thank you so much!
Best wishes!
Qiulan Zeng
[ICEM] ICEM CFD internal Wall by using structured Grid challenger85 ANSYS Meshing & Geometry 17 January 26, 2017 14:04
ICEM CFD 5.0 (Hexa) - Internal Wall/Thin Surface James Date CFX 3 August 10, 2012 05:47
ICEM CFD - minor internal error, number of nodes don't match Anorky ANSYS Meshing & Geometry 0 June 4, 2009 11:41
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 04:39
ICEM CFD 5.0 (Tetra) - Internal Wall/Thin Surface James Date CFX 3 December 24, 2004 08:41
