pointwise import to fluent
Old   September 17, 2010, 12:41
Default pointwise import to fluent
gee
gravxp is on a distinguished road
I wanted to ask if anyone has had experience with a problem I am having with importing a .cas file generated in pointwise to fluent. The grid configration allows some mirroring of elements but I find that when I mirror elements as apposed to build the whole grid from scratch, fluent comes with an error 'no face for the given nodes'. If I build the whole mesh from scratch, there are no problems importing the mesh. would like to know why this is the case. thanks in advance
gravxp is offline   Reply With Quote
Old   September 19, 2010, 16:18
John Chawner
jchawner is on a distinguished road
gee:
This might be happening if you mirror around the symmetry plane and the symmetry plane isn't exactly z=0 (or whatever) the shared faces along the plane aren't really shared. The reason this can occur is if the geometry on which you're building the grid has some variation in coordinates along the symm plane.
I suggest you contact our tech support engineers at support@pointwise.com and they can look at your particular grid to diagnose the issue.
Best Regards
John Chawner / jrc@pointwise.com / www.pointwise.com
Blog: http://blog.pointwise.com/
on Twitter: @jchawner
jchawner is offline   Reply With Quote
Old   September 20, 2010, 08:23
gee
thanks john.
it works when I mirror connectors and faces and build the blocks from these mirrored elements but no joy when I mirror the already constructed block. well done on your software like it alot.
Old   September 20, 2010, 09:11
John Chawner
gee:
I still suggest that you report this to our tech support team so we can diagnose and repair if necessary. support@pointwise.com
Cannot import ANY ICEM hex core into Fluent v6.3!! Robert Perry FLUENT 11 April 12, 2012 05:30
import an mesh file into fluent krishna FLUENT 4 June 11, 2010 00:44
Data import in Fluent?! Bart Horsten FLUENT 3 February 22, 2010 14:05
import Fluent files into CFX wolf CFX 1 June 7, 2007 04:56
Import ICEM Mesh to Fluent Fluent Beginner FLUENT 5 June 23, 2004 01:27
