a cracked Beam
Old   September 17, 2010, 11:09
Default a cracked Beam
Hamidreza
Hamid-Reza is on a distinguished road
Modeling a crack in Ansys:
I am working on transverse crack in beams.
I model the transverse crack using NUMMRG command in Ansys.
in which two geometries must be modeled. In the interface of the two geometries , for the uncracked area, nodes are merged to unify and for the cracked area nodes are left unchanged.
Having implemented the above procedure ,my results are no in good agreement with the theoritical ones, it would be highly appreciated if any one can recommend me a better method for modeling a cracked beam in Ansys.
inaddition, I don't know if I have to use contact element in the cracked area or not.
thanks for your time and help in advance
Hamid-Reza is offline   Reply With Quote
Old   September 21, 2010, 12:33
Default Can't help...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
This is more of a solver questions, and an FEA question at that. You may not get much help in this meshing forum on CFD-online. I myself am only a little familiar with crack modeling and can't really help you out.
Have you contacted ANSYS tech support? Techsupp@ANSYS.com
PSYMN is offline   Reply With Quote
crack modeling in ansys
help on radiation model for a moving laser beam nazeem FLUENT 1 April 20, 2009 11:34
comsol cantilever beam problem bhu47 COMSOL 0 June 30, 2008 15:59
Modeling a fluctuating beam Mehdi FLUENT 5 January 9, 2008 10:47
FSI problem with topology of 3D beam via UDF greg FLUENT 7 July 17, 2006 06:32
Effect of fire on a steel beam Amanda Fry FLUENT 1 January 20, 2004 14:59
