[ICEM] why is the edge color changed?
Old   September 1, 2010, 23:35
Default why is the edge color changed?
ringtail is on a distinguished road
When I open the project, I will find the color of some edges have changed. As the following picture show, it changed to black.
But, if I turn off 'Edges' and then turn it on, the color will come back.
What's the matter?
And when I check the mesh quality, as the below picture show, there are some elements between 0.714717 and 0.72898075. But when I lighten the bar, I can't find anything. And the message is showed as below.
0.714717 -> 0.72898075, 1 values
0 elements
Anybody can help me? Thanks very much.
ringtail is offline   Reply With Quote
Old   September 2, 2010, 09:23
AB
BrolY will become famous soon enough
Open the ICEM help menu and search for 'move vertex'. You will find the explanation about the color of the edges. So, make sure you have associated all your curves with the good edge.
About the 'change color', I have never seen that before.
About the 'missing' element, try to convert your premesh into an unstructured mesh, and see if it happens again.
BrolY is offline   Reply With Quote
Old   September 2, 2010, 09:41
hi BrolY, thanks for your reply.
I have checked the ICEM hlep (v12.0), but it doesn't mention the 'black color' edges. And I'm sure all the edges have been associated with right curves. What's more, I have converted the mesh into unstructured mesh for FLUENT v12, and the mesh works well.
Then, about the 'missiong' element, It has already been convert into unstructured mesh. When I check the premesh, everything seems good.
Old   September 2, 2010, 10:57
AB
When the edges are black, it means that they haven't been associated with any curves and that there are no constrains on the edges.
For the example, when you creat your first block, the edges are black.
About the missing element, could it be an edge or something like that? Anyway, your mesh quality is very good (> O.7 is nice. usually, > 0.3 is good for almost all solvers), so I guess it's not an issue.
Old   September 2, 2010, 16:14
Red face Sorry, I dont know what the problem is, but at least it is not stopping you.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
That is strange (about the 0 elements)... What metric were you using?
As for the edge changeing colors from blue (volume edges) to black (surface associated), I don't have enough info to guess. Are those edges supposed to be in the volume or on the surface? And I have no idea why the color would change.
But in the end, it seems like your quality is very good and you can move on.
PSYMN is offline   Reply With Quote
Meshing a Sphere Ajay FLUENT 10 September 3, 2016 15:18
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
[Commercial meshers] Star mesh import problem chris1980 OpenFOAM Meshing & Mesh Conversion 20 May 8, 2006 02:07
