[ICEM] (ICEM CFD) meshing over a cylinder
Old   August 2, 2010, 13:45
Default (ICEM CFD) meshing over a cylinder
Ugly Kid Joe
vmlxb6 is on a distinguished road
I am using ANSYS ICEM CFD 12.0 . I need to analyze the flow over a cylinder. What I am looking is for my mesh to be more refined around the cylinder and in the path of its wake.
I can make the area around the cylinder coarse by using Prism but what i don't know is how to make the path of its wake more refined ???
Using blocking gets my inner side of cylinder to be mesh also. It doesnt respect the cylinder boundary. It meshed trhu and thru.
vmlxb6 is offline   Reply With Quote
Old   August 2, 2010, 13:52
Timothy
tav98f is on a distinguished road
You should look into "create mesh density." I think that it is designed for just such applications.
tav98f is offline   Reply With Quote
Old   August 3, 2010, 23:09
Default Density Boxes...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
If you want to do it with tetra prism, you should use a density box. Density boxes allow you to set the max size within themselves... You can find them under mesh (tab) => Create mesh Density. These are included in several tutorials, including the "fin" example where it is used to refine a wake.
Blocking would be great if you were using ICEM CFD Hexa... IF you get mesh right thru your cylinder, it is because you didn't delete the block that represents your cylinder. You should definitely go thru some tutorials before trying Hexa.
Simon
PSYMN is offline   Reply With Quote
Old   August 8, 2010, 05:05
Ugly Kid Joe
Thanx Tim and Simon
Old   August 11, 2010, 14:51
Default new material
arif.iut.09 is on a distinguished road
hay everyone, i am very novice ansys cfx user. can any body help me out?i am doing a project on metal casting.can anyone tell me how to define a new material? I want to use aluminium alloy as my casting material.please i need a quick ans. Then again where can i get step by step instructions regarding ansys cfx.the help menu tutorials seem confusing to me. cheers.
ARIF
arif.iut.09 is offline   Reply With Quote
Old   August 11, 2010, 15:34
Ugly Kid Joe
Dude Arif you should create your own new thread !!!! It might help you.
Old   August 11, 2010, 15:37
PSYMN's Avatar
Simon Pereira
Arif, more specifically, a new thread in the CFX solver forum would be even better.
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 20, 2015 00:40
Learn ANSYS ICEM CFD easy_astronaut ANSYS 2 December 15, 2013 16:34
icem cfd ai environment 11.0, laptop keyboard problem, linux pertupd Hardware 3 October 3, 2011 09:27
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent ivanddd ANSYS Meshing & Geometry 1 February 3, 2011 01:51
ICEM CFD Modules Boris FLUENT 1 March 12, 2004 15:37
