July 12, 2010, 23:28 |
merging two faces without losing mesh
Mayur
Rep Power: 16 |
Hi, whenever i merge two faces adjacent to each other which are already meshed, i lose the mesh upon merging. How do i avoid that?
Firstly, I am making them as two separate faces before meshing to get a better mesh. But when i merge them (after meshing) , I lose the mesh ! I need to merge them before sweeping into a volume cause im getting errors in volume after sweeping! Thanks Mayur |
July 13, 2010, 02:10 |
Maxime Perelli
Rep Power: 41 |
I believe you cannot escape to it.
What is the problem with sweeping volumes?
In memory of my friend Hervé: CFD engineer & freerider |
merge face mesh |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 10:01 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 02:08 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
connecting Faces with different mesh intervalls | Franz | FLUENT | 0 | August 30, 2006 06:08 |
import mesh error/warning | Laxminarayana | FLUENT | 1 | February 15, 2005 09:49 |
