[DesignModeler] How to import AutoCAD file into Design Modeler?
Old   April 16, 2014, 13:39
Default After importing IGS file in ANSYS
  #21
Zain
zainsaeed147 is on a distinguished road
After importing IGS file in ANSYS workbench i found about 43 bodies in my model..i want them to be reduced them in to few as the meshing process is taking soo much time for these number of bodies
2ndly how can i make a circular sheet (surface) on concrete surface..?? i have heard that it requires very challenging skills of manual meshing in order to make proper bond between the concrete and the fiber composite layer on it ??
zainsaeed147 is offline   Reply With Quote
Old   July 28, 2015, 10:21
Shaheer
Shaheer is on a distinguished road
Hello I have imported my files in ANSYS successfully however i need to move their position up a bit. I cant seem to be able to do that so far. Once imported its default frozen. I can unfreez them ofcourse but i dont think that will do me any good. I have a shaft ( i need to import it 2 times to have 2 shafts) and then shift each so that they are parallel to each other.
The job is very simple and i am sure i am missing some thing very basic, help would be appreciated.
Shaheer is offline   Reply With Quote
Old   August 7, 2015, 03:02
Kapi is on a distinguished road
HI Shaheer,
Import you shaft once and then Pattern it on the newer coordinate system.
Done!
Cheers
KAPI
Kapi is offline   Reply With Quote
Old   July 28, 2017, 07:24
Smile import external geometry file in ansys workbench from auto cad
  #24
optimus prime is on a distinguished road
https://www.youtube.com/watch?v=-Y1NWiZbbZY
https://www.youtube.com/watch?v=Y8VtWAXL5-U
I have shown how to make a geometry in Auto-CAD and import it in Ansys Workbench.
optimus prime is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
How to import AutoCAD file into Design Modeler? CFD-Jay ANSYS 2 July 13, 2010 22:56
import autocad file ritmat FLUENT 5 June 1, 2007 13:19
