Received exception: Disk full or disk related problem |
I am getting the above error whenever a mesh I try to create reaches around 21 million cells. As long as I have quite a lot of free space in my hard drive, I understand that "disk full" is not the case. Can anyone please explain what is the basis of this problem with huge meshes and if there is anything to counter it?
Thanks. |
Johannes Kneer
Rep Power: 17 ![]() |
Hmm I'm just guessing: have you chosen a filesystem like FAT for your harddrive, that does not support files bigger than 2Gb?
Regards, Johannes
-- Johannes Kneer Institute for Thermal Turbomachinery Karlsruhe Institute of Technology |
Thanks for the reply Johannes. Actually, no. I have an ext3 filesystem on linux.
I am using gambit. It is a cylindrical 3D mesh. Square inside the circle on the bases of the cylinder and extension from the 4 angles to the arcs that form the circle. All elements of the mesh are map. I have 24 Gbytes of RAM on a linux 64.
problem related to mesh | naveen | CFX | 3 | March 25, 2006 08:47 |
Numerical solution to the rotating disk problem? | johny | Main CFD Forum | 7 | September 5, 2005 05:53 |
Problem related to the Error: General-car-0cdr | wei wang | FLUENT | 0 | May 7, 2005 03:03 |
cavitation related problem | Kamran | FLUENT | 1 | June 14, 2004 03:05 |
problem related to staggered grids | zhu | Main CFD Forum | 10 | October 27, 2001 22:30 |
