[ICEM] Icem 12.1, O-grid - sweep combination
Old   June 14, 2010, 03:56
Default Icem 12.1, O-grid - sweep combination
pertupd is on a distinguished road
Hi all,
I am trying to mesh quarter pipe (perforated on perimeter) making use of quarter O-grid blocking (in Hexa).
I would like to save some finite volumes and would like to use two sweet blocking direction in central part of the pipe.
First sweep block direction is along perimeter of the pipe, and is utilized to reduce no. of volumes in axial direction.
The second sweep, in most central part of the pipe, is to reduce no. of volumes in cross section of the pipe.
Problem is that icem, when generating mesh (project to survace), is trying to project face in the middle of the first sweep blocking to nearest surface and thus producing non-regular grid on the face. Icem treat the face as if it was boundary face, but in fact it is interior one. It does not help to disassociate edges of the face.
The only cure is to generate mesh projecting to edges only. But in general, it is not a solution. See attached pics. of resulting mesh in the first sweep middle face for the two projection setings.
How to impell Icem to treat the face as interior one?
Partial solution to the problem is to generate the quarter O-grid by hand (not using automatic O-grid split) and generating central block by hand.
In the case the middle face of the first sweep do not look to be treated as boundary. Though there is some problem when generating overall mesh. The mesh is not generated for the cental part (second sweep) and resulting mesh is only surface mesh.
What might happen in the case?
Thanks for every suggestion.
pertupd is offline   Reply With Quote
Old   June 18, 2010, 15:00
Default Different volume parts?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Usually, if ICEM Hexa is trying to project an internal face to surface, it is because the blocks on either side of that face are in different volume parts so it assumes a boundary.
You can fix these issues generally (all the faces between any two volumes) or face by face using the Associate Face to Surface DEZ... Or you could just make sure that the blocks are in the same volume part.
PSYMN is offline   Reply With Quote
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 04:33
Exporting ICEM Tetra Grid to Fluent with Hexa-Core Tim FLUENT 2 August 30, 2007 08:16
ICEM HEXA Grid Manish Phoenics 0 March 12, 2005 06:07
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
