[ICEM] hole in hybrid mesh
Old   June 11, 2010, 01:30
Default hole in hybrid mesh
malkovitch
malkovitch is on a distinguished road
I have a little issue, i tried to make a hybrid mesh but when i merged the unstructured mesh on the structured mesh, holes were created.
I think it is because of discretization's problem, i put a picture of my issue (enlargement).
i hope somebody could help me
thanks
have a good day
malkovitch
malkovitch is offline   Reply With Quote
Old   June 11, 2010, 09:21
Default Associate Edge to curves?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
First of all, I assume you mean you tried to merge unstructured Tetra with Unstructured hexa?
ICEM CFD Merge Meshes is very robust at this but it has some specific requirements.
My guess is that both sides of the merge were not properly associated to the perimeter of the interface surface. Check your model with the display option (right click on mesh in the display tree) "as dots". This will display the nodes with color coded projection. Turn on just the Interface parts and make sure that both parts have green nodes around the perimeter of the interface surface.
It is also critical that the interface surface(s) be completely shared by both sides of the merge. Make sure that when the part(s) is on, you see quads and tri's overlapping everywhere, there shouldn't be only one side (with only quads or tris)...
If that is not clear enough, I am sure I have written it up more eloquently in previous posts. You could look one up.
PSYMN is offline   Reply With Quote
[Other] hexa vs hybrid mesh convergence Viais OpenFOAM Meshing & Mesh Conversion 0 April 23, 2010 11:39
[Other] Hybrid mesh with GRIDGEN famarcfd ANSYS Meshing & Geometry 2 November 2, 2009 11:53
Hybrid Mesh Marc FLUENT 4 July 18, 2007 21:38
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
hybrid mesh around a stator Michele Cagna FLUENT 2 October 25, 2000 10:12
