[ICEM] ICEM windows disappears
Old   May 28, 2010, 07:40
Default ICEM windows disappears
Valentin
val17lr is on a distinguished road
Hello everybody!
I have a big problem: everytime I try to open a model file (when I press "apply" or "OK") with the workbench readers from ICEM, the ICEM windows disappear. Then I have to open a new ICEM window.
It even happens when I use the "LeftFemur.agdb" file from the tutorial!!
It happens with solidworks, catia, parasolid files... (and much others).
If somebody has an idea, because I made a pressure probe with solidworks, and I absolutly need to use this with ICEM.
I'm using Ansys 12 and Solidworks 10.
Sorry if my engish is poor, I'm french
Hope you could help me
Regards
Valentin
val17lr is offline   Reply With Quote
Old   May 31, 2010, 11:37
Valentin
Up pleaaase!!
Old   May 31, 2010, 23:09
Default Need more info?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
I would love to help, but I would need more than this...
GO into settings and turn on the log file... OR go to the bottom of the message window and turn on that log file.
Then save your project first.
Then try your import. This way, we will at least see that messages came up in the message window.
If that doesn't work, perhaps a screen recording program would give us a better idea.
If you are licensed to use the software, this may be a good time to call tech support.
Simon
PSYMN is offline   Reply With Quote
icem disappear solidworks
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 04:39
RAM usage limit under Windows 64bit / ICEM flga CFX 2 December 5, 2006 04:02
CFX mesh import from ICEM (Windows) Andrew CFX 7 July 6, 2006 12:39
ICEM CFD 5.1 Hex-Tet mesh merging failure bogesz CFX 1 January 29, 2005 07:46
