[ICEM] Structured Mesh 3D Wing Tip
Old   May 19, 2010, 18:09
Question Structured Mesh 3D Wing Tip
Michiel
Michiel is on a distinguished road
I'm trying to mesh a 3D wing body, but i have troubles with the mesh around the tip. See the pictures below.
The geometry consist of a curve for the leading edge and a curve for the trailing edge which end in one point in de tip of the wing body. At the base i have two curves for the wing profile (left and right are separate and symmetric). Finally there are two surfaces (L & R) which closes the body.
At the base I constructed a C-grid, but I cannot finish the mesh al the way to the tip. Most blocks end in one point at the wing tip. I can generate the mesh in ICEM, but when importing this in CFX I get an error.
What kind of bocking strategy should i use?
Michiel is offline   Reply With Quote
Old   May 19, 2010, 21:14
DoHander is on a distinguished road
For the tip I would try to use a hyperbolic mesh generator (not sure if ICEM-CFD can do this), for the main part of the wing a C grid type will do.
Do
DoHander is offline   Reply With Quote
Old   May 19, 2010, 22:09
Default Same problem as i met
Ke peng
kepeng is on a distinguished road
Waiting for advices too.
kepeng is offline   Reply With Quote
Old   May 20, 2010, 22:45
Default Options...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Yes, these can be tough to block... But there are always options.
We could look at doing intersecting CGrids... One to wrap around the wing and one to capture the shape of the profile. At some point on the tip, it would need to transition from rounded to sharp... I would need to look closer to see how that would work out.
We could also look at MultiZone (do you need structured multiblock or are swept/unstructured blocks ok too?
PSYMN is offline   Reply With Quote
Old   October 20, 2010, 22:36
lachie's Avatar
Xu Zhu
lachie is on a distinguished road
same question waiting for addvice too
lachie is offline   Reply With Quote
Old   October 21, 2010, 09:39
iswadi
icemaniac178 is on a distinguished road
i am also going to do almost the same mesh generation. i could not find any tutorial on 3D wing + fluid domain (wind tunnel) simulation using ICEM CFD. i also need some answers and advices.
icemaniac178 is offline   Reply With Quote
[ICEM] 3D wing tip realanony87 ANSYS Meshing & Geometry 3 November 6, 2019 14:34
ICEM - mesh near wing trailing edge Joao Lourenco CFX 5 August 30, 2007 18:20
Delta Wing Structured Grid Riaan FLUENT 3 December 31, 2004 13:03
Can CFX solve problem with structured mesh? Peted CFX 2 June 1, 2004 00:45
Mesh Mignard FLUENT 2 March 22, 2000 06:12
