[ICEM] Exporting Grid Volumes/Areas from ICEM to Calculate Discretization Error
Old   May 18, 2010, 15:12
Default Exporting Grid Volumes/Areas from ICEM to Calculate Discretization Error
Joshua Counsil
Josh is on a distinguished road
Hi -
I'm trying to calculate the discretization error of my CFD simulations using Richardson's method as outlined in the Journal of Fluids Engineering:
http://journaltool.asme.org/Template...umAccuracy.pdf
I created my "2D" (one element deep) structured mesh using ICEM 12. If you observe Equation 2 (fourth page of the above link), you'll see that a representative cell size is required. Basically, I need the following parameters to solve the equation:
N = total number of cells
Ai = area of each cell (the i'th cell)
or...
Vi = volume of each cell
I know how to get N, but I don't know how to export a file from ICEM with the area (or volume) of each cell.
Is it possible to export a file from ICEM with the volume of each cell? If so, how?
Thanks for any help!
Josh is offline   Reply With Quote
Old   May 19, 2010, 13:05
Default Hmm...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
There are diagnostics that create a historgram for a property such as volume, but I don't know how to do exactly what you want. I will look into it and get back to you...
PSYMN is offline   Reply With Quote
Old   May 19, 2010, 20:48
Joshua Counsil
Thanks, as always, Simon.
Old   May 20, 2010, 12:58
Default Scripting...
PSYMN's Avatar
Simon Pereira
Not sure how comfortable you are with scripting, but I think it will be the only way to produce a file with this info for each element.
You will need to look into the programmers guide and tcl scripting in general, but I asked one of my friendly neighborhood developers (actually he is on a different continent) for some tips and he sent me this...
At least it looks easy for the surface elements.
Enjoy...
There exists 2 commands to get volume/area information.
set area [ic_uns_area $subset_name]
set vol [ic_uns_volume $subset_name]
What the user needs to do is to create a subset ($subset_name) for each element in the mesh and to write this information into a file.
The following existing ic_ command writes the area information (only for shell elements) into a file:
ic_uns_write_elem_list all ./my_file_name
Output format of the file is
"element number" "area" "element node numbers"
Hope that helps a little.
Jari
Old   May 20, 2010, 14:40
Joshua Counsil
Thanks, Simon. Chances are I'll never get around to doing this, but it's good to have this as a reference should I have the time to try it.
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 19:54
POSDAT problem piotka STAR-CD 4 June 12, 2009 09:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Compiling OpenFOAM13 on AMD64 with OpenSUSE 101 silent_missile OpenFOAM Installation 5 August 10, 2007 08:31
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
