[GAMBIT] GAMBIT 2.4.6 on Ubuntu 10.04
Like Tree1Likes
Old   August 16, 2010, 18:50
Yves Delannoy
Yankee is on a distinguished road
Originally Posted by enry View Post
Hi guys,
I found very interesting these post. I solved the problem of trapped mouse as the posts suggests, but I have a problem when I update my ubuntu. The problem of trapped mouse reappear after updating. Have you got the same problem?
Thanks in advance.
To avoid losing your patch when updating you can simply mark the packages that you've built yourself as "blocked" in synaptic (if you use this apt frontend). This will prevent any upgrade, but don't forget to look regularly at the available version in official sources (that is also displayed in synaptic), and release this 'blocked' option when you think an upgrade is necessary (for example, for compatibility with other packages...). Then you'll have to re-test, and if the problem still exist, to rebuild with the patch...
Yankee is offline   Reply With Quote
Old   August 16, 2010, 21:28
mundhwam is on a distinguished road
yeh..solution: when you update, deselect the update for x-server in the update manager.
mundhwam is offline   Reply With Quote
Old   October 15, 2010, 04:26
Olivier
olivierG is on a distinguished road
hello,
Since this bug is not fixed in ubuntu 10.04 LTS, an easy work around is to add ppa repo from Cris Carlin (add ppa:crcarlin/ppa) in system software source.
This will update the xserver
olivier
olivierG is offline   Reply With Quote
Old   February 9, 2011, 11:08
Default Thanks!!!
  #24
Mohamed Yousuf
usyusuf is on a distinguished road
the procedure helped to fix the bug
usyusuf is offline   Reply With Quote
Old   February 9, 2011, 11:14
Olivier
On ubuntu 10.04, the bug is now fixed in the last official update, so we don't need crcarlin repo anymore, just upgrade.
olivier
Old   June 9, 2011, 08:19
alillou
alilou is on a distinguished road
i can't install gambit on windows seven edition familial 64 bits!
please help me!
alilou is offline   Reply With Quote
Old   August 27, 2011, 18:36
Default specify the architechute
  #27
Shoonya is on a distinguished road
Originally Posted by bugra View Post
hi,
I tried this but It's not running still. Is there another thing to do?
I think once you will specify the architecture of your machine, gambit should start.
e.g for 32 bit machine :
open ".bashrc" file
export FLUENT_ARCH="lnx86";
save it and in terminal $ . .bashrc
now follow earlier suggestions
Dinesh
Shoonya is offline   Reply With Quote
Old   October 27, 2011, 12:56
Sofiane KHELLADI
skhelladi is on a distinguished road
If it may help, I solved the problem on ubuntu by installing libc6-i386, which is a 32-bit shared libraries for AMD64 architectures.
skhelladi is offline   Reply With Quote
Old   April 11, 2012, 02:08
AHMED
navedahmid is on a distinguished road
Dear dinesh, I have emailed you on your gmail account, we can discuss that matter there plzz.
navedahmid is offline   Reply With Quote
Old   May 22, 2012, 07:37
open ".bashrc" file
Dinesh
After doing above steps if you find permission denied problem then go to the license file and unlock it ( It must be locked somehow)
right click > properties > permission > access-- read and write
then you should be able to execute gambit on terminal using aforesaid command
[GAMBIT] gambit 2.3.16 on ubuntu 10.04 binjiestudent ANSYS Meshing & Geometry 13 February 28, 2017 15:39
Ansys fluent 13.0 on ubuntu 10.04 mundhwam FLUENT 2 September 1, 2011 11:14
Uninstall Gambit on Ubuntu 10.04 ClothMelon FLUENT 0 December 6, 2010 15:19
ANSYS FLUENT 12.1.4 on ubuntu 10.04 mundhwam FLUENT 0 June 28, 2010 16:34
Gambit 2.4.6 help! Oskirrii FLUENT 4 June 9, 2010 18:01
