[ICEM] Creating Simple Geometry
Old   May 10, 2010, 13:21
Default Creating Simple Geometry
Patrick Young
Mudblood is on a distinguished road
I'm new to CFD and need to create a mesh in ICEM. The geometry that I need to create is quite simple. I need to create a rectangular prism with a relatively small cylinder inside running parallel to the long edge of the prism.
Could someone explain to me how to do this or direct me towards a tutorial? Everything that I can find about ICEM does not use ICEM itself to create geometries, but that is something that I need to do. Thanks!
Mudblood is offline   Reply With Quote
Old   June 8, 2010, 21:26
Default Geometry steps.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
ICEM is a surface based modeler, so you build up geometries from entities.
in this case, you would start with 3 points from coordinates...
The first would be the middle of the circle, the second, a point on the radius and the third would establish the plane... So maybe 0 0 0, 0 1 0 and 1 0 0. Then create a circle with these three points. Pick the center first, then the point on the radius and then the point in the plane. This would give an R=1 circle.
Then create 4 more points. Lets imagine at -20 -20 0, -20 20 0, 80 -20 0 and 80 20 0. Then create curves and pick each pair of points. This would create a box 100 units long by 40 units tall.
Then to create the extrude depth, create a point in Z, such as 0 0 50.
Then use the surface create tools to extrude by a vector... Select the center of the circle and select the 0 0 50 point, then select all the curves. They will be extruded by the vector (0 0 50) to create the geometry. Then create surfaces from 2 to 4 curves and select the 4 curves on either side of the box to close it in.
Build topology (or modify surface => segment with a curve) to cut the sides of the box with the circles.
Finally, delete the round sides of the cylinder (assuming you don't want a solid material in the cylinder).
It is pretty easy for simple stuff, but not as flexible as more advanced CAD tools.
PSYMN is offline   Reply With Quote
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
Importing CAD geometry and Editing edges to match Ahmed CFX 15 March 21, 2016 13:39
Meshing on simple geometry pukiwawa FLUENT 5 August 31, 2008 13:04
Creating 3D Elbow Geometry in GAMBIT Shubha FLUENT 3 June 2, 2008 12:28
creating geometry in CFX5.5 adam CFX 5 July 17, 2002 10:55
