[GAMBIT] 3D skewed elements
Old   April 28, 2010, 00:01
Default 3D skewed elements
chris21 is on a distinguished road
I am modelling a thin slice of a turbine blade cross section. The cross section is formed by revolving a cross sectional path and then splitting the turbine blade volume with the revolved path. When I go to mesh the geometry surrounding the blade, all of the faces are fine except for one. When I attempt to mesh it, it gives me a highly skewed mesh warning. Normally I would reduce the mesh size, but the skew is actually protruding from the face, in 3 dimensional space, even though there is no material there because of the revolved split. Why could this be happening? If I reduce the size of the mesh, it does not protrude so far, but it still protrudes and will not let me produce a useable mesh.
chris21 is offline   Reply With Quote
Old   April 28, 2010, 06:10
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
post a picture
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 6, 2010, 22:15
Ah, sorry to take so long to reply, I was on holiday for a week. It turns out that something went wrong at some point with a projected edge that didn`t quite make it to the correct position. Everything seems to be working now, but thanks anyway.
skew
Can highly skewed elements create problem?? Sanjay Jain FLUENT 1 April 8, 2008 16:57
skewed, inverted elements exp FLUENT 0 June 15, 2007 12:56
what to do w/ highly skewed elements? (GAMBIT) mike FLUENT 5 June 2, 2007 23:10
Highly skewed elements Hengky FLUENT 2 August 11, 2005 13:17
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
