[ICEM] Question about boundary type recognition when import mesh from IcemCFD to Fluent
Old   April 22, 2010, 05:50
Default Question about boundary type recognition when import mesh from IcemCFD to Fluent
dean is on a distinguished road
Hi all,
First of all, thank you for viewing my post.I am trying to make a pipe with velocity-inlet (in the center)and pressure-inlet(around previous one with cirque shape) at one side of the pipe, the other side is pressure-outlet by using ICEM. when i use tetra meshing, it was perfect
read by Fluent with boundary condition. however, when i try to use hex meshing, there always omit the center part which defined in ICEM, only read these two parts as a entity(a round surface boundary),the name is recognized as either velocity-inlet or pressure-inlet. i need to use VOF model in Fluent. hope you can help me which i really appreciate Have a nice day!
i think i have solved this now,thank you all
but how about a quarter or semi-cylinder assosication?
Last edited by dean; April 24, 2010 at 17:22. Reason: probblem solved,thank you all :)
dean is offline   Reply With Quote
Old   April 23, 2010, 11:13
Default How did you solve it?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
I assume the problem had something to do with associations or blocking material?
Since you solved the problem yourself, how about posting what it was so others who may be having the same problem can fix it also.
Simon
PSYMN is offline   Reply With Quote
Old   April 23, 2010, 11:17
Hi Simon,
Thank you for replying my post.i change to O-grid to apply blocking assosiation.and, is that you put lecture on the youtube?i really like it
have a nice weekend
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 05:53
[mesh manipulation] Using createPatch in place of couplePatches sripplinger OpenFOAM Meshing & Mesh Conversion 8 November 13, 2009 08:14
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
