[GAMBIT] simple mesh problem
Old   April 15, 2010, 11:07
Default simple mesh problem
李逾
yubaibai88 is on a distinguished road
dear all:
I'm new in Gambit modeling.
now I've obeyed all the tutorial told me to do in gambit tutorial 2.after I save my finished gambit file and then export mesh file.the console windows says:
export fluent5 "pipe.msh"
a default(unspecified) boundary entity was created.
continuum or boundary condition specified on entity (edge.8) is invalid for fluent 6
my .msh file haven't been exported.
could anyone tell me what can I do about it
yubaibai88 is offline   Reply With Quote
Old   April 15, 2010, 11:29
Chris
Chris D is on a distinguished road
Is it a 2D grid? If not, then you should be setting boundary conditions for faces, not edges. What boundary condition are you setting on that edge?
Chris D is offline   Reply With Quote
Old   April 15, 2010, 11:39
李逾
hello:
thanks for advance,I solved it by enable the "Exprot 2-D(x-y) Mesh"
but could you tell me why I must enable it in order to export msh,and what are the differences between enable/disable the buttom
thank you
Old   April 15, 2010, 12:21
Chris
If it's a 2D problem, then you need to export it as a 2D grid. In 2D, there aren't any cells in the z direction, which would give you problems if you tried to tried to solve it as 3D.
Old   April 15, 2010, 20:01
李逾
I know it,thank you very much
Moving Mesh Run problem - Scientific Linux G. SE Siemens 2 May 7, 2008 08:15
Problem with Output to .cfx5 mesh Ben CFX 4 January 24, 2008 18:47
Very simple moving mesh Pete FLUENT 4 February 10, 2006 01:12
Problem with rotational mesh deformation: Part II NymphadoraTonks CFX 2 November 4, 2004 04:05
mesh control problem TUM CFX 4 July 27, 2001 17:17
