[Other] Meshing application launch
Old   April 12, 2010, 12:26
Default Meshing application launch
mohammad nazzal
mnazzal is on a distinguished road
I'm working with Ansys 12 Workbench to develop a response spectrum model for a dam section. I'm using the custom model provided by Workbench.
I opened the design moduler and created my geometry and then converted that into a surface since I only need a 2D model hence a 2D mesh is needed.
I saved the work, returned to Workbench, right click the Mesh cell only to get to the following error message: "Unable to start the mechanical editor".
Did anyone come across this error before?
To avoid this, how can I launch the CFX-Mesh application directly? Instead of going through the mechanical editor?
I'm new to Ansys, so sorry for my proimative questions.. Thanks..
mnazzal is offline   Reply With Quote
Old   April 14, 2010, 01:06
Default Bad project?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
I have never seen that error, so this is just a guess, but if it happened to me, I would save the geometry (export), then toss out the workbench project, create a new project and import the geometry... If that didn't fix it, I would send the geometry file to someone else (maybe techsupp or CFD-Online) to see if they could get it to work (indicating an install problem)...
Simon
PSYMN is offline   Reply With Quote
Old   April 14, 2010, 01:42
mohammad nazzal
I did reinstall but did not work. I tried exporting the geometry and then creating another project and importing, same story.
I even tried importing other geometries from provided examples and I did get the same message. Yes, it is an install problem. I did contact tech support. Meanwhile, is there any way to get around the mechanical editor? Why can't I launch CFX-MESH in stand alone mode?
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
Dyamic Meshing application in IC Engine using CFX pratikmehta CFX 0 September 26, 2009 18:14
Anyone with turbo application meshing experience ? bearcat FLUENT 1 October 18, 2007 10:29
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 12:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 12:08
