[GAMBIT] Help neeeded for 3D taylor-couette
Old   March 30, 2010, 21:05
Post Help neeeded for 3D taylor-couette
Ron88 is on a distinguished road
Hello everyone, I was trying to get some help creating a geometry for a 3D taylor-couette cell in gambit.
I'm trying to model rotating flow between two concentric cylinders - the inner rotating, and the outer stationary. I created three concentric cylinders of equal height and successively decreasing diameter, and subtracted the middle cylinder from the outer cylinder, to get my desired geometry. I meshed it and assigned "wall" as the boundary type to both cylinders, but I'm at a lost as to what to do for the fluid between them. Again, it's in 3D (even though it doesn't look like it here).
Thanks for any help!
Ron88 is offline   Reply With Quote
Old   March 31, 2010, 02:32
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
You meshed the solid parts...
You need to mesh the fluid domain which is squeezed between the 2 solid parts (delete those 2 solid-volumes)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   March 31, 2010, 11:44
Thanks, will try it and let you know how it goes!
Old   April 1, 2010, 12:46
Max, seeing as I'm now focusing only on the fluid between the cylinders, I'm confused as to assigning the boundary layers to the four faces...I also need to be able to set the rotation speed of the inner face.
Old   April 12, 2010, 01:50
-mAx-'s Avatar
Maxime Perelli
In the Wall Boundary Condition, you can define the rotation speed
Momentum/Wall Motion
How make F3D to reduce a time step many times down to dtmin? gennady FLOW-3D 1 January 28, 2010 13:12
F3D v9.3 argir FLOW-3D 3 April 15, 2009 19:11
Export in F3D Ali FLOW-3D 5 December 4, 2008 01:42
