Two Sided wall Problem
Old   March 26, 2010, 14:37
Default Two Sided wall Problem
Mark
Mk1987 is on a distinguished road
Hello everyone, Im currently working on a 2d axisymmetric Rotor/Stator investigation within fluent, Ive not been formally taught CFD and am having trouble modelling a solution.
Im using Ansys Workbench v12 Fluent for my analysis, and have a Cavity between a rotor and stator, the rotor is said to rotate at a certain rpm with the fluid applying a moment onto the rotor, this produces a power onto the fluid and it heats up. Suitable Inlets and outlets are setup allowing the model to reach energy equilibrium.
The next stage is modelling a solid rotor of given dimensions. Ive setup a energy outlet in the form of a constant temperature at the far side of the rotor.
____ ____
| |SOLID|
|Fluid | |
_____|_____|
The wall between the Fluid and Solid is said to be rotating at the given speed about the centre x axis. This heats up the fluid and solid and naturally their should be a heat transfer between the two. However Fluent appears to solve the solid temperature and fluid temperature independently despite my best efforts. After investigation, it appears i need to couple the walls, however fluent will not let me do this. I Believe it is due to the way my mesh is setup, the named selection Rotor Wall (the boundary line) is split into 'Rotor Wall-fluid' and Rotor Wall - Solid', their is no 'Rotor Wall - Shadow' and therefore the option to thermodynamically couple the walls is not available. Within the workbench mesh facilities ive tried to 'connect' the walls but it makes no difference. I believe its due to the way the meshing tool imports two seperate surfaces, therefore two edges exist for the fluid/solid wall, ive tried having a named selection for one edge and two edges, and it makes no difference. If anyone has an idea as to where I might solve my problem, that would be greatly appreciated.
Regards
Mk1987 is offline   Reply With Quote
Two Sided wall Problem Mk1987 ANSYS Meshing & Geometry 0 March 26, 2010 14:09
Problem Interface Solid Fluid with wall velocity Solver v12 hills1 CFX 2 October 12, 2009 06:36
Wall surface reaction problem llnudt FLUENT 0 March 14, 2007 10:43
moving wall BC problem Sourabh Main CFD Forum 1 August 8, 2006 08:47
The problem of wall data getting when postprocessi WIlliams Siemens 4 March 6, 2006 11:14
