[GAMBIT] semi-circle meshing
Old   March 24, 2010, 08:44
Default semi-circle meshing
Rúben Ramalhais
Ramalhais is on a distinguished road
Hello everybody
I need to mesh a semi-circle in GAMBIT 2.2.30 using only quad elements and mapped (can´t use PAVE because my UDF doesn´t work well with it).
Can anybody help my with the disposition of the vertex and edges to make it work? I know that I have to use 4 edged faces but using a square inside the circle isn`t helpful, at least by now.
Thaks for your help
Rúben Ramalhais (ruben_ramalhais@hotmail.com)
Ramalhais is offline   Reply With Quote
Old   March 25, 2010, 03:06
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
why it is not helpful?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   March 25, 2010, 06:24
Rúben Ramalhais
Because I can mesh the square (face), but in the other faces GAMBIT complains about the number of elements, I´ve tried to alter the number of the edges elementes but still can´t mesh the other faces...
Ramalhais
Old   March 25, 2010, 07:47
-mAx-'s Avatar
Maxime Perelli
are the other faces mappable? (Gambit chooses automatically Map schema?)
Old   March 25, 2010, 08:17
Rúben Ramalhais
No, the GAMBIT automatic options are elements:Quad; Type:tri primitive. But if I try to mesh with this option, an error mensage apear:
ERROR:number of intervals on meshed edges of face, does not allow mesching using de scheme of tri primitive.
If I use Type: map, GAMBIT mesh the face but with element quality value of 0.5, wich isn´t good because when I run FLUENT an error occurs due to mesh problems.
Old   March 25, 2010, 09:05
-mAx-'s Avatar
Maxime Perelli
Enforce Map, as you did.
Mesh Quality (skewness) of 0.5 is good.
I don't think the problem comes from that
Old   March 25, 2010, 09:30
Rúben Ramalhais
Is incredible but my UDF works with perfectly regular elements (I´ve tried it with just a square) but when I use it with some distort elements allways occur an error in FLUENT such as AMG solver. I´ve tried it whithout my UDF and FLUENT runs well so it lead me to think that is not a mesh problem, is actually the interaction between my UDF and the mesh...
I´m going to use this mesh and see what happens!
Best regards, and thanks for you help
Ramalhais
[blockMesh] I thought about this solution to create a spherical mesh. sega OpenFOAM Meshing & Mesh Conversion 9 May 24, 2008 07:15
meshing circle pace Main CFD Forum 2 February 20, 2008 05:26
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 06:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 12:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 12:08
